front lug nut
front lug nut
one of my front lug nuts broke off. I can still partially screw in the nut and tighten it. I can't find a DYI on acurazine. I saw some post on youtube calling for shaving the bolt and cutting out the back plate so as not to pull the bearing. Any tips on 2004 TL AT.
I have done this many times on TL's. It's pretty easy. It is a tight fit, but it'll come out with a hammer. when putting back in you cant hammer it because the tightness will bend some of the threads. Shave off a couple mm of the edge on the stud head to clear the hub.
nanos
Nov 12, 2015 08:41 PM
