Foglights in headligts?????
Old Feb 18, 2011 | 01:02 PM
cali_04_tl's Avatar
I figured sumthin out bout my 04 tl...my low bean and high beam is on the same bulb...however then second bulb (which is normally the high beam bulb) is acutally a fog light...is this normal or is there sumthin wrong wit my car...will take pics as soon as ii get out of workk...
Old Feb 18, 2011 | 01:09 PM
SharksBreath's Avatar
BANNED
yeah you've got 2 projectors in each headlight.
1 is your headlight (low n high beam)
1 is your foglight
not sure what you mean by
am i understanding you correctly? i'm in for pics.
Old Feb 18, 2011 | 01:10 PM
^base 04-06 tl's have one projector.
the high beam and low beam's are integrated. it uses a flap, so when you switch the high beams on, the flap flips up.
you can hear it taking place, as it flips up and down.
So the OP is correct when he says that the 2nd bulb is a fog light.
Old Feb 18, 2011 | 01:13 PM
rockstar143's Avatar
and yes, it's totally normal. it is dumb...but normal.
You can look up the accord fog mod...where you dremel out your lower grill to accomodate normal fogs.
Old Feb 18, 2011 | 01:15 PM
BANNED
ok...so one projector in each headlight for hi/low beam.
what's the other part called towards the center of the car (in the headlight)?
wouldn't you consider that fog lights?
Old Feb 18, 2011 | 01:16 PM
fogs.
Old Feb 18, 2011 | 01:19 PM
BANNED
fogs.
i know that man, sorry.
i guess i shouldn't have used the term "projector"
Old Feb 18, 2011 | 01:25 PM
^the 07-08s have dedicated drls.
we just have crappy fog lights.
Old Feb 18, 2011 | 01:37 PM
I would totally swap out for a type-s headlights but i would lose my fog lights....
and the accord fog light mod does not provide enough light because of how the bumpers are angled on the 04-06s
Old Feb 18, 2011 | 01:47 PM
cali_04_tl's Avatar
Ok ill get the pics up as soon as i get out of work....any1 put differnt color bulbs in the fogs???i was thinkn bout changing them to yellow...
Old Feb 18, 2011 | 01:51 PM
your pics would look like 04-06 TL headlights.
and these cars have been out since 04. you can bet your bottom dollar that everything you can think of, its been done before.
I only use the fog lights, in fog.
Old Feb 18, 2011 | 02:44 PM
stvtec's Avatar
'06 WDP TL 6MT
+1 and I keep my headlights on everywhere I go, just because I like the way it looks.
Old Feb 18, 2011 | 03:05 PM
nate_0022's Avatar
Land of 10,000 lakes
Like said. Our HID headlights are called bi-xenon which means they're both high and low. There's a solenoid on the bottom of the projector that flips the cut off shield down making it a high beam. The other opening is your fog/auxiliary low beams, I don't think it makes sense to have it integrated into the headlight but whatever works.
Old Feb 18, 2011 | 06:02 PM
Bearcat94's Avatar
AZ Community Team
Yes. This info is all over the forum; almost every day.
Just browse the 1st page or two of the main 3G forum and you'll find a half dozen threads on headlights, fog lights, tail lights and LED's.
You can also look at this link to answer 80% of questions about mods, DIY, etc.
https://acurazine.com/forums/3g-tl-2004-2008-93/3g-tl-garage-faq-3g-tl-newbies-553554/
quanaman
Jan 9, 2023 07:33 PM
Jul 16, 2017 07:33 AM
shinybluecls
Nov 16, 2005 12:00 PM
ST2000
Aug 14, 2003 02:47 PM
