Transmisson issues????
Old Feb 18, 2011 | 07:31 PM
MrKinn's Avatar
I have a 2004 70,000 miles automatic.. I have noticed this has been an issue for months now.. but not really sure whats causing this.. If i just normally accelarate ..... when my speed reaches about 38 mph is hesitates ever so slightly.. as it shifting ( from 3rd gear to 4th ).. If i accelerate at a more rapid pace i dont believe this issue occurs.. Is something up with my ttansmission?? or what?? anyone else have this issue??
Old Feb 18, 2011 | 07:33 PM
SpiderX1016's Avatar
I'd change the 3rd and 4th gear switches and do a 3x3 drain and refill. That should do it.
Old Feb 18, 2011 | 07:35 PM
MrKinn's Avatar
A WHAT????????????
Old Feb 18, 2011 | 07:47 PM
Bearcat94's Avatar
AZ Community Team
The 3rd to 4th hesitation at moderate speed is common in that trans. Happens in some Accords too.
https://acurazine.com/forums/3g-tl-2004-2008-93/3g-tl-garage-faq-3g-tl-newbies-553554/ - best thread in the forum; bookmark it.
A-110: DIY: Guide to replacing 3rd & 4th gear pressure switch for 3G TL https://acurazine.com/forums/3g-tl-2004-2008-93/110-diy-guide-replacing-3rd-4th-gear-pressure-switch-3g-tl-2004-2006-a-729149/
C-025: DIY:The RR Journals: ATF drain and refill (Automatic Transmission Fluid Change
https://acurazine.com/forums/ramblings-12/anybody-good-xp-89064/
C-026: DIY:ATF drain and refill (Automatic Transmission Fluid Change
https://acurazine.com/forums/3g-tl-2004-2008-93/c-026-diy-changing-atf-pics-745892/ - Pictures inside!
Old Feb 18, 2011 | 08:18 PM
MrKinn's Avatar
So nothing to worry about???
Old Feb 18, 2011 | 08:26 PM
Bearcat94's Avatar
AZ Community Team
I'd still look at changing the pressure switches and doing a full 3x3 drain and refill on the ATF.
Old Feb 18, 2011 | 08:29 PM
MrKinn's Avatar
How is this done?? Do i need to take this to the dealership?? Or is this something a newbeeie can do?
Old Feb 18, 2011 | 09:32 PM
I hate cars's Avatar
Read the threads provided, everything you need to know is there.
snorf
Nov 4, 2019 06:44 AM
Kres43
1G RDX (2007-2012)
Oct 3, 2015 07:16 PM
Frathora
Sep 28, 2015 11:29 PM
tristann616
1/2G MDX (2001-2013)
Sep 22, 2015 11:40 PM
carz0159
Sep 20, 2015 06:11 PM
