Fog lights stopped working
Old Sep 11, 2009 | 06:09 PM
j1n's Avatar
j1n
Ok well i installed HID fog lights a couple months ago. now they both don't light up when i turn them on. i'm guessing its a connection or electric problem since they are both dont work.
im going to take the bumper off again and test it with the OEM lights and see if it works.
just looking for tips on what to look for to fix it. i took the front bumper off last night just to check the connection to them and it looked solid. what else should i look for?
Old Sep 11, 2009 | 06:19 PM
ifirahse's Avatar
SlammedOnKonis
Did you have them wired with a relay? If not you might've blown a fuse I'm guessing.
Old Sep 11, 2009 | 06:27 PM
KB1Spec's Avatar
Check fuse, relay, grounding the wire and tighten everything.
Old Sep 11, 2009 | 07:09 PM
j1n's Avatar
j1n
Ok took the bumper off swaped it with the OEM bulb and still nothing.
How do i check the fuse? i opened up the fuse box and i have no idea which one it is and how would i tell if its blown?
also what and where is the relay? would the relay effect both sides?
im starting to think its the fuse
Old Sep 11, 2009 | 07:38 PM
j1n's Avatar
j1n
OK took some pics.
Is this the fuse for the HIDs?
if not which one would be the fuse in the main fuse box?
and here just a pic of the OEM bulb o hanging on the light
Old Sep 11, 2009 | 07:46 PM
KB1Spec's Avatar
WHen you take out the fuse box cover, it should say which fuse for the foglight. So check the diagram on the back of the fuse box cover. Correct me if I'm wrong, inside the driver side kick panel there are an additional fuse box as well. Check on that as well.
Old Sep 11, 2009 | 07:57 PM
j1n's Avatar
j1n
Ok i found the fuse for the Fog lights. i took it out and it looks fine..... how can you tell if its blown? is there something you look for to tell if its blown or do you just replace it and see if that was the cause?
Old Sep 11, 2009 | 08:08 PM
brimp's Avatar
There is a relay (at least on my 04) for the fogs as well, worth checking...
On the 04 it is next to the engine compartment fuse box, in its own little compartment.
Old Sep 11, 2009 | 08:15 PM
j1n's Avatar
j1n
OK i got it. fuse IS blown. look at it closer in better lighting and i can see that its burnt out in the middle.
space_boy
ILX
51
Aug 15, 2017 12:06 PM
theinsvnity
Sep 10, 2015 10:22 PM
cruisingnycfl
Sep 2, 2015 12:11 PM
prox
5G TLX Problems & Fixes
Sep 1, 2015 02:03 AM
ptbarnett
3G RLX (2013+)
Aug 30, 2015 12:39 PM
