Fog light troubleshoot
Old Apr 28, 2011 | 10:46 AM
jurena's Avatar
2004 NBP ACURA TL
ok so i finally had the balls to remove the front bumper by myself, thanks to sandiegodrive DIY video .
i literally spend the whole morning trying to take off the bumper off
yes im a complete noob.
well heres my problem, i had 5000k hid fogs but some idiot hit my car while it was parked, so the leftside bulb was damaged. just recently i bought 3000k hid bulbs from HIDEXTRA. i removed the bumper and plugged in the new bulbs, when i turn the fog lights on they work but 10 seconds later the leftside bulb turns off. i turn them on around three times and it keeps doing the same thing.
i was wondering if any of you guys know what might be the problem?
Old Apr 28, 2011 | 10:50 AM
SharksBreath's Avatar
BANNED
did you get the relay harness as well? sounds like that's what is going on.
Old Apr 28, 2011 | 01:00 PM
djflex167's Avatar
check your harness mines whats a little messed up and when i replaced it it worked fine eversince!!
Old Apr 28, 2011 | 01:09 PM
vladkarnafel's Avatar
UA7 NBP TL-S
might be a bad ballast, take the other ballast from good working side and troubleshoot if its the ballast or defective bulb, but definitely install a relay kit for fogs.
Old Apr 28, 2011 | 02:12 PM
AckTL05's Avatar
Former Sponsor
+1, sounds like a bad ignitor and with these after market one the ignitor is integrated into the ballast.
Old Apr 28, 2011 | 03:36 PM
jurena's Avatar
2004 NBP ACURA TL
The bulbs came with the wires that connect to the relay, I already had an hid kit installed before all I did was unplug the old bulbs and plug in the new one.
I even switched the bulbs out and when I put the rightside bulb on the the left side they stayed on longer but they would turnoff after 20 seconds.
Old Apr 28, 2011 | 04:50 PM
UA7 NBP TL-S
They both turn off after 20 sec??
its your ballasts for sure, or both bulbs defective.
Old Apr 28, 2011 | 06:11 PM
jurena's Avatar
2004 NBP ACURA TL
Just the leftside would go off.
Old Apr 28, 2011 | 07:39 PM
UA7 NBP TL-S
Than for sure its a bad ballast.
InFaMouSLink
Oct 27, 2015 06:51 PM
sockr1
Oct 1, 2015 01:31 AM
ellisd03tls
Sep 8, 2015 04:17 PM
cruisingnycfl
Sep 2, 2015 12:11 PM
prox
5G TLX Problems & Fixes
Sep 1, 2015 02:03 AM
