Fog light problem
Old Jan 3, 2016 | 09:22 AM
imeyers725's Avatar
Fog light problem
Trying to change the fog light bulbs in a 2004 TL. Passenger side took about a minute. For the life of me I cannot get the bulb out of the drivers side. No matter how I try to turn it or wiggle it, it will not budge. Any suggestions? Never had a bulb that would not come out.
Old Jan 3, 2016 | 09:27 AM
guitarplayer16's Avatar
Use heavy duty gloves and use full power.
Trying to use full power without gloves hurts the fingers so you can't really give it 100%.
There's debris lodged between the bulb and the socket overtime.
Old Jan 3, 2016 | 09:46 AM
imeyers725's Avatar
Good idea. Tried it without gloves first time.
Old Jan 3, 2016 | 10:35 AM
tk2k6's Avatar
Try to loosen the 3 screws that the lightbulb twists under when it locks. There's also a possibility that the socket part of the lightbulb is melted or expanded with heat. Stick a phone+light in there take a picture and examine it closely.
Old Jan 3, 2016 | 11:20 AM
imeyers725's Avatar
Thanks, will try that too. Just did the headlight restoration. Came out amazing. Lelse's were shot before.
upload foto
pic upload
photos upload
upload picture
Old Jan 3, 2016 | 12:03 PM
tk2k6's Avatar
That looks awesome. My headlights look like your "before" pictures but for some reason I always thought the glare is on the inside of the headlight since I've seen a lot of moisture inside. What kit did you use to restore them? I was looking at the turtlewax restore kit for $7.97 to buy.
Old Jan 3, 2016 | 01:51 PM
imeyers725's Avatar
This is the kit I used from 3M. Works with any drill. The have another kit that you can use by hand but the drill just makes it easier and faster.
http://www.autogeek.net/3m-headlight-kit.html
Old Jan 3, 2016 | 03:34 PM
csmeance's Avatar
Turtle wax kit works great! The only issue is the "supplied clear coat/finish".
Most of these kits clearcoat/final finish lasts only a year before turning yellow again. I've found Blue Magic Headlight Sealant on amazon for $6 and put it on the headlamps 1x a month. Looking new after I used the turtlewax kit years ago.
Old Jan 3, 2016 | 06:42 PM
01acls's Avatar
If you wax it on a regular basis it will stay clear bc waxing remove oxidation and applies uv protection.
travr6
Oct 30, 2017 04:21 PM
atsx1313
Aug 30, 2016 12:18 AM
rexflexall
Jan 5, 2016 12:31 PM
kapikap
1G RL (1996-2004)
Jan 4, 2016 08:04 AM
calgaryjdmua5
Dec 29, 2015 08:12 AM
