Trying to change the fog light bulbs in a 2004 TL. Passenger side took about a minute. For the life of me I cannot get the bulb out of the drivers side. No matter how I try to turn it or wiggle it, it will not budge. Any suggestions? Never had a bulb that would not come out.
Try to loosen the 3 screws that the lightbulb twists under when it locks. There's also a possibility that the socket part of the lightbulb is melted or expanded with heat. Stick a phone+light in there take a picture and examine it closely.
That looks awesome. My headlights look like your "before" pictures but for some reason I always thought the glare is on the inside of the headlight since I've seen a lot of moisture inside. What kit did you use to restore them? I was looking at the turtlewax restore kit for $7.97 to buy.
This is the kit I used from 3M. Works with any drill. The have another kit that you can use by hand but the drill just makes it easier and faster.
Turtle wax kit works great! The only issue is the "supplied clear coat/finish".
Most of these kits clearcoat/final finish lasts only a year before turning yellow again. I've found Blue Magic Headlight Sealant on amazon for $6 and put it on the headlamps 1x a month. Looking new after I used the turtlewax kit years ago.
