FM reception problems
Old 02-18-2017, 04:39 PM
Mason Fox's Avatar
Hey so I have a 2006 acura tl, base with nav us model.
I've looked all over but all I get is something about xm.
I've tested fm/am/xm radio and only my fm radio has reception problems. Any ideas on how to fix this?
Old 02-18-2017, 04:46 PM
Received 8,597 Likes on 6,640 Posts
Do you have tint on your rear windshield
Old 02-19-2017, 04:20 PM
Mason Fox's Avatar
No it does not
Old 08-08-2017, 01:06 PM
BreezyTL's Avatar
Reviving a dead horse. Is there any resolution other than removing rear TINTS? My reception is mediocre to say the least and on cloudier days it is almost non-existent... I don't wanna do satelite radio with subscriptions and my cellular device only has 3 gig plan. Don't feel like upping my data cuz I am paying $115/month already.
Old 08-08-2017, 01:45 PM
peter6's Avatar
Yeah sure, burn some CDs.
Old 08-08-2017, 02:06 PM
BreezyTL's Avatar
What are those?
Old 08-08-2017, 03:38 PM
Jackass's Avatar
Or make a mix-tape.
Old 08-08-2017, 03:43 PM
Jackass's Avatar
If you are paying that much for a single phone, you are doing it wrong.
Antenna issues....I don't recall too many threads that successfully identified FM reception issues that weren't caused by tint, broken connection at back window, or a bad FM modulator was in the path. Only other item I can think of is if the jack behind the head unit came loose. I have never taken this car apart to know how that is setup to know if that is likely or not.
Old 08-08-2017, 04:06 PM
BreezyTL's Avatar
When I install my Short Shifter, I will take a peak behind there. I believe the antenna is reachable.
I know about the phone. I am paying too much for it for such little Data. I need to change services or my plan.
Old 08-08-2017, 04:34 PM
b15
b15's Avatar
Are you certain it is your tint causing reception issues?
I had FM reception issues couple months ago, turned out that my 12V usb adapter was going bad. When my phone wasn't plugged in it was fine. Plugged it in and got static.
Old 02-06-2021, 05:57 AM
bakaryu18's Avatar
Hey I am having the same exact issue XM radio works great no static, CD player works checked the back of the radio FM/AM connection was plugged. Everything is plugged in radio has lights, asks for code accepts code, Displays work.
FM/AM still does not work. What could it be? Is the Antenna on the roof for XM only or where is the FM/AM antenna? could my radio tuner be bad? help please.
miner
3G RLX Audio, Bluetooth, Electronics & Navigation
05-22-2019 08:09 AM
Doh21061
11-22-2013 03:52 PM
ttefabian
04-20-2007 11:59 AM
timdaley73
30
08-09-2004 08:45 AM
Quick Reply: FM reception problems
