Flashing Interior emergency lighting
Old Jan 8, 2012 | 09:58 AM
jokerman826's Avatar
Jokerman
When i turn on my emergency flashers, every light in the car except the overhead are flashing with the blinkers, This has been happening ever since I installed the LED turn signals and made the front marker lights white, but has become real noticeable now that i have converted my interior to LED. Every single light that i converted from incandescent to LED now flashes with the emergency blinkers. Does anyone have clue to what is going on?
Old Jan 10, 2012 | 01:38 PM
invalidalias's Avatar
may wanna find a different ground to use, Or wire into a fuse rather that directly into a power from another 'power' wire.
Old Jan 10, 2012 | 06:27 PM
Jokerman
I am talking about all of my stock wiring and bulbs, nothing added in or moved. I have LED turn signals and I converted to LED button back lighing. I have not done anything to any of the stock wiring for these items
Old Jan 14, 2012 | 12:21 PM
Jokerman
an other ideas?
Old Jan 23, 2012 | 07:04 PM
arn809's Avatar
sometimes wiring may need a relay and a different ground. try that...
Old Feb 5, 2012 | 04:52 PM
Jokerman
What do you mean need a different relay and what should I change the ground on. Now I have noticed that all the dash lights flash when i put my turn signal on. This is starting to get aggrivating. All the dash lights will flash with the turn signals. If i turn on the dash lights, like you would do at night, the lights do not flash. Now all of this started to happen after the interior LED conversion. I still have no idea why this could of happened.
Old Mar 30, 2012 | 11:58 PM
Jokerman
I have an update on this. After looking around on the internet, i decided that the problem may be the LED turn signal bulbs. I removed the front bulbs and the issue stopped. I discovered that with both sides that the signal that gets sent to the bulb to flash feeds back through the parking light circuit and in turn flashes all the lights for illumination. I bent the leads on the LED bulbs to make them a 7440 style and they still flash but since there is no path to the other circuit the other circuit stays off (doesnt flash interior lighting)
Now all i have to do is figure out which component is messed up in the car that is allowing the power to be fed back through the wrong circuit. I figured there should be a diode somewhere preventing this, but cannot locate exactly where it would be.
I have tried two different styles of LED 7443 bulbs and they both do the same thing.
Any suggestions on what i should check out next?
Old May 3, 2018 | 08:50 PM
JDM96specCTR's Avatar
sorry to bump a 6 year old thread, but im dealing with this same exact issue and this is the only thing ive been able to find dealing with it. whenever signaling with the headlights off, all the interior lights flash and the navi switches day to night on each flash. i figured out that the front signal lights are feeding the issue, since one stopped contacting the running light filament the issue stopped on that side. with the bulbs out the flashing doesnt happen, with the low (dim) filament out it doesnt happen. i have normal signal bulbs not led and have tried different bulbs with no difference. anyone else experience this?> would be a miracle if jokerman could update lol
also i do have led dash lights, some of which blink on and off randomly.
Old Oct 13, 2018 | 03:50 PM
Jokerman
So, ultimately u had to put diodes in line with the parking light coming from the fuse box in the engine compartment. this allowed electricity to flow to the bulb but prevented the electricity flowing back into the car, thus stopping the flashing interior lights.
rockyboy
Aug 4, 2024 10:35 AM
Feb 25, 2020 09:57 AM
RLX-Sport Hybrid
3G RLX (2013+)
43
Dec 16, 2015 10:45 PM
PortlandRL
Sep 14, 2015 12:01 PM
HeloDown
Sep 8, 2015 06:51 PM
