Fix for door dings?
Old Nov 21, 2005 | 11:30 AM
bonedoc76's Avatar
7th Gear
Fix for door dings?
I was just the victim of an ignorant holiday shopper....got caught up in Best Buy yesterday, and was dismayed to find someone had nailed my passenger car door, down by the door sill with their car door...I have a SSM, and there is now a dark gray ding, through the clear coat....so frustrating, when I normally try and park to avoid such problems....
I'm sure this thread has come up before, but what do people recommend as far as fixing this? When I run my finger over it, I can feel the ridges (several fine scratches and one big one) so I know it is through the clear coat, but it doesn't look down to metal... Is there a way to get the paint off and then buff it, then put a new coat? Kind of new to this, so I don't want to make it worse.
I would appreciate any advice so that I can patch up my pride and joy.
Old Nov 21, 2005 | 11:46 AM
A-Spec Guy's Avatar
B A N N E D
Contact your local dent doctor paintless dent repair. You will be suprized how much they can make it look better for cheap!
Old Nov 21, 2005 | 11:52 AM
bonedoc76's Avatar
7th Gear
thanks....what about the dark paint from the other door? Any way to get that out/off?
Old Nov 21, 2005 | 01:01 PM
Brettg's Avatar
I should wax off.
Old Nov 21, 2005 | 02:54 PM
A-Spec Guy's Avatar
B A N N E D
Yep....the dent guy will polish it out most likey....the only thing that will be there is any scratch in the paint...and they can usually lessen that effect too. There is somebody else on there that just got it done on a REAL nasty scratch on their back door and it looked wonderful...look around. It was on a black car if I remember.
Old Nov 21, 2005 | 03:29 PM
derrickmosley's Avatar
The absolute correct fix is usually around $125 per ding by the professionals. The little machines they use are doing a lot of work and you should be able to work some kind of deal for multiple dings.
Old Dec 20, 2005 | 09:25 PM
TL-Rocks!'s Avatar
I'm in the Santa Clara area (Bay Area, CA) and I used a good place recently. "Dings and Dents". I had a half-dollar sized dent from some schmuck with a car door and though the dent was pretty deep and the deepest area had a sharp ridge, they worked it out for only $80! The guy that owns the place worked on it; his name is Joe Currin, 408-246-0021. I'm passing this info along because he did a great job and was very professional with 10+ years experience in body work. He was even able to buff out some minor clear coat damage. Hope this helps.
Old Dec 22, 2005 | 03:05 PM
Godwinrb's Avatar
Man, the same thing happened to me at my local BestBuy in Maryland. I didn't have a scratch but I did have a nice dent. I contacted a company called Dent Wizards and he pulled it out. It looks great, can't even tell it was there. He charged me around $100.
Good Luck with your fix.
Old Dec 23, 2005 | 12:47 AM
subinf's Avatar
One on the right for me
dent removal service is great. i had a pretty bad door dent with paint missing (not bare, but scratched) the dent was fixed and they reduced the scratch so its nearly impossible to see...i have no idea how they did it but its gone now.
tman570
Jun 11, 2019 07:56 AM
giovane
2G RDX DIY & FAQ
Jul 8, 2016 10:46 PM
BoricuaTL
Apr 8, 2016 01:08 PM
Oakes
Wash & Wax
Nov 12, 2015 09:34 PM
Azonics
Sep 22, 2015 05:28 PM
