First problem 08 TL squeeking from belt
Old Aug 12, 2013 | 07:55 AM
micro23's Avatar
Love my 08 TL had it a few months now with not a single problem. 47kmiles Just yesterday on the way home from the Airport I heard some squeaking coming from a belt under the hood with low/no acceleration.
This video seems to describe my problem perfectly.
How much labor is involved in this repair? It seems the belt is only like $20.
I believe this is the fix/problem could someone verify? https://acurazine.com/forums/3g-tl-2004-2008-93/there-diy-serpentine-belt-697723/
Dealer quoted $175 for parts and labor. Said same day service "it should take about an hour"
Old Aug 12, 2013 | 08:08 AM
nttstt444's Avatar
The serp belt takes less than 5 min to change.
Old Aug 12, 2013 | 09:39 AM
eaglegreen48's Avatar
2017 TLX TECH V6
I could be time to change the tensioner.
Old Aug 12, 2013 | 10:09 AM
micro23's Avatar
Spot on guys. Looks like a 10 minute job and $30. Going to have a local friends shop do it instead of the dealer for $175.
Thanks as always.
Old Aug 12, 2013 | 12:13 PM
ZOMGVTEK's Avatar
Was the dealer going to charge you $175 to change the drive belt?
You could probably get someone at an Autozone/Advance sort of car part store to change it for you in the parking lot. It takes just a few minutes and very little skill.
I prefer the Goodyear Gatorback belts, part should be 4060840 for your car. You can get ones for about $10-20, the Gatorback is probably a bit more.
Old Aug 12, 2013 | 01:21 PM
ez12a's Avatar
the overexplainer
sounds like a dry bearing more than it does a belt squeak. Ditto the earlier suggestion and take a look at the drive belt tensioner while you're in there.
Old Oct 19, 2013 | 07:29 AM
Derek_08TL's Avatar
7th Gear
My '08 just hit 40K miles and last week as I was driving through a covered bridge I heard a similar sound. I took it to the dealer since I needed the power steering hose recall done anyway. They determined it to be a bad "drive belt tensioner". I hoped the powertrain warranty would cover it but not so. Original quote was $275 but they decided to cover 75% of the cost. Picked up the car last night and the sound is gone. Seems to be pretty common with these cars.
Old Oct 19, 2013 | 07:35 AM
TLtrigirl's Avatar
3G TL/2G MDX Owner
i had that noise in my TL for 3 days...then it went away. could be the timng belt chirp issue...covered under TSB, not sure if the 08's are covered under it.
Old Oct 22, 2013 | 01:03 AM
poli's Avatar
I had the same noise but after 2 days the noise went away and now i have whining noise every time i turn my stearing wheel when the engine ic cold.
vaughanml2
Nov 1, 2021 10:16 AM
pstomps
Feb 20, 2017 03:29 AM
stalloutboy
Apr 25, 2016 10:28 PM
Kitsune13
Sep 24, 2015 02:25 PM
mossman77
1/2G MDX (2001-2013)
18
Sep 16, 2015 12:21 PM
