Engine Whining?
Old Oct 21, 2013 | 12:53 PM
tehloxely's Avatar
Engine Whining?
Hey guys!
A few months ago, I heard this whine coming from my engine. It was a low whine, and when I turned the steering wheel it got louder. The Acura I went to said the accessory belt needed to be changed. So I did that, but now it's back. What do you think it is?
Old Oct 21, 2013 | 12:57 PM
imakeholesinu's Avatar
Had this exact issue with my 2006 TL. Cold start, and there was a whine until the car heated up especially in cold weather. What it might be is that the Power Steering pump has lost suction around the replacement O-Ring and is sucking air into the PS system. Take it back to the dealer and have them fix it under the o-ring recall.
Old Oct 21, 2013 | 01:27 PM
tehloxely's Avatar
Do you happen to have the information on that recall?
Old Oct 21, 2013 | 01:35 PM
http://owners.acura.com/service-maintenance/recalls The O-Ring should have been replaced when they replaced the Power Steering hose. If they didn't do it that is likely what is causing the noise.
Old Oct 21, 2013 | 03:43 PM
EvilVirus's Avatar
OP dont take it in for just the o-ring replacement. DIY its easy and wont take no more than 5 minutes.
IIRC there is thread in the garage section that will show you.
Edit- After re-reading this, do you have any leaks? How is your steering i.e. hard to turn? You said that it gets loud when you turn which may indicate your rack n pinion.
It would help if you gave us the mileage of the car.
Old Oct 21, 2013 | 05:43 PM
MarcoNorthPolo's Avatar
KCCO
Yeah, the first thing I thought of was power steering.
Old Oct 22, 2013 | 12:35 AM
poli's Avatar
i have tthe same problem on my type s 07 but the noise is only when the engine is cold after it warm up the noise goes away.
Old Oct 22, 2013 | 11:42 AM
EvilVirus's Avatar
Replace the o-ring dude
Old Oct 23, 2013 | 05:13 PM
tehloxely's Avatar
I have 188k miles on my car. No leaks. Steering is fine.
It looks like they've did that recall already.
Code:
Description
2004-2008 TL Power Steering Hose
Type
Safety Recall Campaign
Status
Fixed
The noise, for me, just started happening at random. Maybe it was cold, maybe it wasn't. I can't remember. But it is getting cold out...
Old Oct 24, 2013 | 10:14 AM
Right but they probably didn't replace the O-ring where the hose connects to the pump and that is failing which is where the air is getting pulled into the system and making the noise.
My 06 with 130K had this issue all Winter until the car got warm. If you let it go it may ruin the pump since it is working harder to move fluid through the system and letting air into it which is likely dirty and contaminating the PS fluid, and then you have larger issues to deal with. Replace the O-Ring or take it back to where you had the hose replaced and have them replace the O-ring. Depending on how the PS fluid looks also you might want to flush it and replace it as well.
Old Oct 29, 2013 | 09:56 AM
EvilVirus's Avatar
Any update OP?
SidhuSaaB
May 30, 2020 12:40 AM
joflewbyu2
Oct 8, 2015 11:16 AM
ROSSARONIE
Oct 2, 2015 11:46 AM
TL14
Sep 24, 2015 04:37 PM
STL TL-S
Sep 23, 2015 08:52 PM
