Engine whiney noise?
Old Oct 21, 2009 | 07:27 PM
simonsez's Avatar
A-SPEC
Hello all,
Just wondering what could cause engine whiney noise (sounds like super charger noise)
it only happens on low gear driving... 1st thru 2nd gear.
i have a/t
i currently have 80000 miles on the car
Old Oct 21, 2009 | 07:39 PM
540idinan's Avatar
I have it too, only noticeable when im driving slow. I have 6mt @ 67k
Im thinking a bearing somewhere or maybe alternator whine but i've been too busy to investigate.
Old Oct 21, 2009 | 08:28 PM
skippyTL's Avatar
I heard that it was a belt tensioner, but I could be wrong... Mine does it too.
Old Oct 21, 2009 | 11:31 PM
Opel's Avatar
make sure its not ur streering pump, and check the fluid level also
Old Oct 21, 2009 | 11:53 PM
TL|GTX's Avatar
A Black TL
even if u arent turning it could still be that?
Old Oct 22, 2009 | 10:59 AM
cdp5095's Avatar
04 tl
i am also having the same problem .. i change the timing belt and water pump. i was told it was the a/c tensioner and the power steering. 04 tl 62k.
Old Oct 23, 2009 | 12:43 PM
Opel's Avatar
yes, if worn out, or pump has a bad bearing, it will be loud enough to hear even at idle.
id be able to tell u whats whining if i was in front of the car looking and listening...its hard to point out a noise from here lol...just giving you possibilities.
example, when the accessory tensioner gets lose it will rattle, make squeeky noises etc.
so if its a continous whine, im almost positive its the steering pump going bad. im just speaking from my own experience with every possible noise that came outta my engine bay lol.
you still gotta check for urself though...i can't be too sure. but let us know what you find
Old Oct 23, 2009 | 01:02 PM
DimwitRj's Avatar
that ONE RED tl
My car has the same whine as the op, I doubt it's the p/s pump as described by you since it only happens in 1st & 2nd gears.. so you wouldn't be able to hear it standing in front of the car. It really does sound like a faint supercharger sound. Subscribed - curious to know toooo.
Old Oct 23, 2009 | 02:14 PM
TL|GTX's Avatar
A Black TL
Yes i the whine is only common in 1st and 2nd gear, and sometimes its not even thier. And i only have 15k miles i dont think its a p/s failure
Yikes
May 3, 2021 04:29 PM
Feb 25, 2020 09:57 AM
snorf
Nov 4, 2019 06:44 AM
iCrap
Sep 11, 2015 06:21 PM
Mike Bertram
Sep 10, 2015 09:27 AM
