Engine shakes when hovering at 1500rpm
Old May 25, 2013 | 03:11 PM
ArAbiAnArAb's Avatar
I've had my 2008 acura TL for almost a year and half now (bought with 83k miles and I got 105k now) and I've had this problem ever since I've had it. I don't notice any slippage in gears but whenever I cruise at low speeds and I hover at 1500 rpm, the engine shakes and everyone in the car can feel the shaking. It seems as if its shaking as its switching from first to second gear. The shaking doesn't happen if I accelerate constantly but happens only if I hover at first then give it a slight acceleration. Any ideas on how to fix this? Thanks for the help!
Old May 25, 2013 | 03:36 PM
My"S"exyUA7's Avatar
You're at 105k's...have you done the big service on it yet?...timing belt, water pump, etc.
Old May 25, 2013 | 03:49 PM
No I have not...I was looking at doing the timing belt soon though..in the last 3 months I started hearing a slightly different sound once I turned on the car (pre warmed up)...I'm guessin that might have somethin to do with the timing belt..is it true that both should be done at the same time (belt and water pump)?
Old May 25, 2013 | 04:23 PM
You don't have to, it's just recommended. Doing it at the same time saves labour (cause they're down there anyways) and ensures you're good for another 105k's...for an example, you don't want to change just the timing belt and then the water pump blows around 20-30k's later. Me personally would do both...the 105k service is around 850 or so in canada and that comes with timing belt, water pump, plugs and others.
Old May 25, 2013 | 04:26 PM
Plus they could check out why your engine shakes...my guess would be a broken engine mount.
Old May 25, 2013 | 04:44 PM
Okay thanks for your help! I think I'll d
Old May 26, 2013 | 05:32 AM
Turbonut's Avatar
I'd say it's normal unless the check engine light is on. Put it in neutral and raise the RPM's to the 1200/1500 range and you'll feel the vibration.
There was a TSB for the 2004 cars, but many have had the problem. Haven't heard it much for the '07-'08 as the engine mounts were changed. Just check the mounts to be sure they're not damaged.
Old May 26, 2013 | 05:53 AM
ATLS_666's Avatar
3 2 GONE
So if you feel the vibration at 1200 to 1500 its the mounts? Acura said they felt the vibration as well but theu blamed it on my stage 2 exhaust.
Old May 26, 2013 | 10:30 AM
Well it's really between 1500-1700 rpm..I'm not an expert at all but it seems like it does so from first to second gear..and this is only if I accelerate slowly and constant..from 0-60 (highway) I don't feel any shaking..
Old May 26, 2013 | 10:32 AM
Btw, I have a check engine light that come on and off on its own but I'm gettin the catalytic converter code (p420) nothing else..
Old May 26, 2013 | 04:14 PM
No...he said shaking not vibration. IMO, vibration is exhaust and shaking/rocking would be engine and/or trans. I've never had this "shaking" so I was just throwing it out there. No one else was helping him at that...I was high, leave me alone.
Old May 26, 2013 | 05:57 PM
Yea it's more shaking then vibrating. I gotta add something in where if I brake or right after I brake (like I would brake and then a second later) it would auto brake on its own. It is really weird. Again, it doesn't happen everytime. It's more like every now and then.
Old May 26, 2013 | 07:52 PM
When's the last time you had your brake fluid flushed?
Old May 26, 2013 | 08:20 PM
nfnsquared's Avatar
Plugged converter?
Old May 26, 2013 | 10:49 PM
I never did it, but I've had the car like 18 months or so. It only happens after I start braking, where once I start braking and regardless of me letting go of the brake pad, it'll brake on its own (its almost as if it lowers gears on its own, like somene is decelaring using the triptronic).
Plugged converter?
not sure what that is?
Old May 27, 2013 | 10:53 AM
08TList's Avatar
for your shaking issue it sounds similar to the issue i have the trans in my 08 base. If you linger around 1500 my car will shake/vibrate, enough so that a passenger could notice it. I changed out my pressure switches a few thousand miles ago even though my car just hit 47,000 miles. It helped but the real change came when i changed the tranny fluid. I first used DW-1 from honda and then switched to redline D4, still need do a 2x3 and so on but it did seem to help my shaking issues. I can definitely still induce the shaking if i needed but its much harder now.
Hopefully this helps with your problem, it can be really irritating
Old May 27, 2013 | 02:13 PM
I was thinkin about changin my tranny fluid..but a lot of ppl have old me not to do so..how long has it been since you've changed your tranny fluid?
Old May 27, 2013 | 02:25 PM
Old May 27, 2013 | 02:30 PM
Get the tranny and brakes flushed out and see how it feels...hopefully it takes at least one problem away.
Old May 27, 2013 | 04:56 PM
ok ill let you know whats up in a few days..thanks
Old May 27, 2013 | 05:21 PM
Was the trans fluid ever changed before you bought it?
Old May 28, 2013 | 12:34 AM
not that I know of
Old May 28, 2013 | 07:58 AM
^ definitly do that first!
Old Jun 17, 2013 | 03:04 PM
vr6vdub's Avatar
Does it do it at a stop in neutral? My car did something similar only on a slight incline.
Old Jun 17, 2013 | 06:13 PM
pohljm's Avatar
yeah thats easy get fluid and switches for the tranny and your other issue regarding the car continuing to brake is actually the "grade logic" in the transmission. it provides additional engine braking when it senses your going downhill and have applied the brakes.
SidhuSaaB
May 30, 2020 12:40 AM
joflewbyu2
Oct 8, 2015 11:16 AM
ROSSARONIE
Oct 2, 2015 11:46 AM
TL14
Sep 24, 2015 04:37 PM
STL TL-S
Sep 23, 2015 08:52 PM
