Engine Making a Nasty Noise When its Below Temp Outside
Old Feb 19, 2006 | 01:25 AM
TranTL's Avatar
Im from Minnesota and its been freaking cold here since Friday. Saturday it got down to -12 Degrees with -32 Windchill! When i went to start my car for work it barely wanted to start, When it did start. Engine was making a really nasty sound like I cant even describe it really. But After the car warms up it goes away. When i drive now i notice a sound like something is Clunking around in my Engine. It is a Very Light sound though. I would have to turn off Air/Radio All the way to mayB hear it.
Is this Normal for the car when its Extremely Cold out?
Thanks in advance for any Feedback
Old Feb 19, 2006 | 01:35 AM
Tufferson's Avatar
i noticed when its really cold and i turn the wheels to make a tight turn and apply the gas the car makes some sound like my tires are gonna fall off. i dont know what thats all about. when its plugged in though starts like a dream, must say i am impressed with that
Old Feb 19, 2006 | 01:47 AM
Riu's Avatar
Riu
2004 TL
Plugged in?
Old Feb 19, 2006 | 02:35 AM
BrandonClaps's Avatar
Originally Posted by Riu
Plugged in?
block heater
Old Feb 19, 2006 | 10:49 AM
Tufferson's Avatar
i love saying plugged in to americans or even canadians from down east cuz most of them are like you plug ur car in?
Old Feb 19, 2006 | 06:27 PM
SodaLuvr's Avatar
Use a synthetic 5w20 for the easiest starts in extremely cold temps. The noise *might* be caused by the extremely thick oil and little flow from the oil pump at such cold temperatures. A synthetic oil would allow for easier pumping here.
Old Feb 20, 2006 | 01:21 AM
TranTL's Avatar
HEY Thanks for the replys everyone!
Old Feb 20, 2006 | 01:26 PM
Rapid1's Avatar
if you need to operate your TL in those kind of temperatures, you really should have a block heater installed. most engine wear occurs at startup and no oil will flow sufficiently in below zero temperatures. a block heater will also help the starting system which is redlining at those temps.
Old Feb 23, 2006 | 01:45 PM
montyburnz's Avatar
I'm from MN too and it was freezing last weekend. After parking outside when I started the car, the TPMS kept going off because the PSI had dropped below 30 on the times. Obviously it's due to the cold weather but it was annoying after a while when it would nag. But it was cool to see that it was working and doing it's job. The car didn't have any problems starting though. Although sometimes I notice it takes a while for the car to turn over in the morning but I think that's due to emission controls.
Feb 25, 2020 09:57 AM
2012wagon
Sep 29, 2015 04:21 PM
iCrap
Sep 11, 2015 06:21 PM
Mike Bertram
Sep 10, 2015 09:27 AM
dlknight
Sep 3, 2015 07:54 PM
