Engine leaking oil? 07 Type S
Old Jan 21, 2017 | 11:56 PM
Asianemia's Avatar
Does anyone know what this leaking might be? I have an 07 Type S.
Old Jan 22, 2017 | 02:09 AM
srg818's Avatar
How many miles? Rear main seal or power steering fluid.
Old Jan 22, 2017 | 12:17 PM
Asianemia's Avatar
140k. It could be the rear main seal possibly. After looking up other TL and rear main seal, it looks like similar leakage. I also notice leaking from the front of the engine. I'll take pictures later and post them
Old Jan 22, 2017 | 10:44 PM
Asianemia's Avatar
Asianemia's Avatar
Could it be an gasket leaking all the way to the bottom?
Old Jan 22, 2017 | 10:50 PM
Valve cover gasket
Old Jan 22, 2017 | 11:40 PM
Asianemia's Avatar
Even though the build up is above the gasket?
Old Jan 22, 2017 | 11:41 PM
Asianemia's Avatar
Could it also be the PVC valve? I really hope it isn't a rear main seal
Old Jan 22, 2017 | 11:47 PM
Have you popped open those coils to see if there's oil in there? Have you ever done the valve adjustment and gasket? They have the spark plug tube gasket too I believe
Old Jan 22, 2017 | 11:52 PM
Asianemia's Avatar
I changed the spark plugs 100 miles ago. There was no oil inside except for a lot of rust on the plugs. I haven't done a valve adjustment also. Just bought the car two months ago. If I do replace the valve gasket, I'm for sure also doing the valve adjustment myself. But I work and go to school 24/7 and have no free time at all :/ I drive to work every day which includes the weekend. Might take a day off just for the TL if I have too.
Old Jan 23, 2017 | 08:03 AM
alexb92's Avatar
Looks more like the PCV valve to me, considering the oil is above where the valve cover gasket is.
Old Jan 23, 2017 | 01:05 PM
Si_jeff's Avatar
OP, at your miles, look to change out PCV valve, Valce cover gaskets and spark plug tube gaskets (they come in a set) , also your PS pump might also be leaking. These are all routine maintenance that should be done. Lots of useful info on this site that covers these DIY's.
Old Jan 23, 2017 | 01:30 PM
Asianemia's Avatar
I do notice the steering is sort of stiff but someone told me it's just the Type S style of stiff steering
Old Jan 23, 2017 | 01:38 PM
Your best bet is to clean it all off and see where it's leaking from now.
Old Jan 23, 2017 | 07:59 PM
Asianemia's Avatar
I'll keep you all posted on the progress. =D What do you recommend cleaning it with? Brake Cleaner?
Old Jan 23, 2017 | 09:14 PM
srg818's Avatar
Engine degreaser.
