Engine clacking?
Old Jun 26, 2014 | 09:36 PM
phlyxaznxboi's Avatar
Engine clacking?
hi guys
so i had my TLS for almost 6 months now there is this weird clacking by the pullys but i cant figure out what it is, after months of research it looks like it could be the Harmonic balancer AKA Crank Pully that needs replacing? i check the Alternator, AC compressor, idle pully/tensioner and brand new drive belt all is good.
anyone experiencing similar issues or know what this is?
video is at above link
thanks.
Old Jul 3, 2014 | 11:01 AM
i guess no one else has this issue or no one really knows what it is?........any leads or advice/confirmation would be greatly appreciated thanks.
Old Jul 3, 2014 | 01:56 PM
Adobeman's Avatar
The DVD-A Script Guy
I'd remove the belt and then spin each accessory/pulley you can by hand to see if one of them has play or "growls" a bit.
You could even run the car for a short period without the belt to see if the noise is gone. BUT - Having not done this myself with a 3GTL I don't know if you will throw a code or not. If you did a battery disconnect, wait, reconnect would probably clear it.
Old Jul 3, 2014 | 04:16 PM
ZOMGVTEK's Avatar
I would pull the drive belt, and inspect anything that spins. That will probably check out just fine, so the next step is pull the timing cover and take a look at the tensioner with the engine running.
Old Jul 3, 2014 | 05:36 PM
bauermd's Avatar
I had the same issue and it was the tensioner pulley bearing going out. I took the drive belt off, and hand spun all of the pulleys I could so feel/listen for any kind of hard resistance. If you look from directly on top of the pulleys, you would normally be able to see if the harmonic balancer is out of alignment. Just eyeball a hardspot on the ground, and line it up with the balancer and see if its out of wack. Just a thought.
Edit: car has to be running for the checking of the harmonic balancer.
Old Feb 7, 2015 | 07:17 PM
so i went to a shot that used a scope to listen to all the parts and they advised that it was the alternator, i just changed out the alternator clacking still there........damn it. i dont know what else to do at this point.
Old Feb 7, 2015 | 09:17 PM
csmeance's Avatar
^ I had the same exact issue, once the tensioner was replaced the sound was gone for almost 30K miles! I've had it come back so I'm going to replace it again when I do the TB/Waterpump service.
Old Feb 10, 2015 | 05:48 PM
was it the tensioner pully for the accessory belt or the timing belt?
thanks!
Old Feb 10, 2015 | 06:18 PM
csmeance's Avatar
thanks!
it was for the accessory belt
Old Feb 12, 2015 | 02:47 PM
csmeance did you replace the whole thing item # 2 below?
Old Feb 12, 2015 | 06:23 PM
csmeance's Avatar
I believe so according to the dealership paperwork.
An easy way to see if it is the tensioner is to remove the accessory belt and turn the car on for a short time. If you don't hear it then it's the tensioner! If you do hear it, it might be the timing belt tensioner.
Old Feb 16, 2015 | 03:35 PM
so i took off the belt this weekend and checked it it looks like it is the accessory belt tensioner, but the funny thing is when i bought the car last year supposely they had already done that before i picked up the car. i will replace even the old bolts this time and see what happens. thanks for everyones help.
Old Mar 2, 2015 | 02:34 PM
Angry change the bent tensioner
so i change the belt tensioner and used all new bolts, put the new belt on, and the clacking is still there. i dont get it. at this point i think its either there is a loose piece of metal somewhere or its the harmonic balancer, i even swapped out all of the spark park plugs just to get that out of the way and make sure its not a loose sparks
after taking the belt off again and run the car the sound is gone, put the belt back on the sound is there again
with the belt off i did observe the harmonic balancer or AKA crank pulley wobble just slightly, but nothing that should cause the clacking.
i guess replace the harmonic balancer and see how that goes.......
Old Mar 11, 2015 | 01:11 PM
not sure if anyone knows or still follow this thread but....
https://acurazine.com/forums/third-g...ppened-927072/
Old Mar 11, 2015 | 04:49 PM
FamilyGuy's Avatar
Yup totally sucks
Old Mar 11, 2015 | 08:43 PM
rjep1953's Avatar
I had a similar clack noise, came on at cold engine start-up, went away at higher rpm over idle, sounded like hydraulic lifts. Took belt off, made no difference. Put long screw driver to the timing belt tensioner and listened- exact source of noise. Changed timing belt, timing belt tensioner & idler pulleys, noise gone. Try the screwdriver-stethoscope method on your moving parts?
SidhuSaaB
May 30, 2020 12:40 AM
BIGxRED
Oct 19, 2015 10:47 PM
joflewbyu2
Oct 8, 2015 11:16 AM
ROSSARONIE
Oct 2, 2015 11:46 AM
STL TL-S
Sep 23, 2015 08:52 PM
