Emergency help needed!!
Old Apr 14, 2018 | 11:48 PM
Nikkole_p612's Avatar
okay so about 2 weeks ago my I was driving stopped at gas station to get gas pumped and then went to start my car and it sounded like a gun shot had gone off. Seen little smoke come up from under the hood so checked it out well the intake manifold had shot out the backside 5 bolts. Having to get the car home walked next door to auto store got longer bolts and it’s put them on Intake drove home took manifold off and noticed it was slightly broke so for temp fix jb welded it and changed gaskets put it back on the car when crank up idles at 2-3 rpms put in drivekinda goes down but then jumps up and down while driving. (It’s horrible makes ya wanna throw up) well now today it shot through the oil pan I’m guessing it rattles and I can see oil under the car everywhere. I know I have to replace the intake manifold and map sensor now guessing I need to replace oil pan but is there anything else I should check for damage? Can anyone tell me why my car has done this and what can I do to fix it?
Old Apr 15, 2018 | 07:32 AM
Joecop67's Avatar
Is this real?
Old Apr 15, 2018 | 07:39 AM
Pair of TLs's Avatar
Slap in a new air filter and you should be ready to go
Seriously..whut??
Old Apr 15, 2018 | 02:33 PM
pics please
Old Apr 16, 2018 | 02:24 AM
Levon05TL's Avatar
Sounds like you got an active shooter situation going on in there.
Old Apr 16, 2018 | 08:24 AM
Jackass's Avatar
A see a few issues here:
1.) Your engine may not run, but your sentences sure do run on.
- Someone stole your punctuation.
2.) Intake manifolds don't just blow up and be OK to just put longer bolts in to drive.
- Guessing failure of something in valve train started this
3.) A hole in the oil pan pretty much means something internal has failed in a catastrophic manner.
- probably time for a new engine
greengables
Oct 20, 2012 09:47 PM
ZUMBABWE
Oct 2, 2012 06:30 PM
kingofdust
Apr 10, 2012 03:59 PM
simko
Jul 28, 2007 08:56 PM
MJS_RENAMED
Dec 25, 2003 10:58 PM
