ECU reset through drive by wire system?
Old 08-15-2007, 03:38 AM
phidalgo's Avatar
With my old car (an '02 maxima), I could reset the ecu by pressing on the accelerator in a specific manner without having to unplug the battery from the car and losing all my settings.
Is this possible with the 3gen tl? If so, what is the procedure?
Old 08-15-2007, 11:45 AM
01tl4tl's Avatar
Received 1,137 Likes on 1,067 Posts
On gen2 cars you pull the "backup clock fuse" not to be confused with the regular clock fuse
Disconnect that for 5 minutes ( maybe less) and you should be cleared in the ECU
radio settings and such- I have no idea
Old 08-15-2007, 05:12 PM
06 TL 6spd. Navi/A-spec
Xx06SickspdTlxX's Avatar
Not that i know of, your best bet is to just disconnecting the battery for 30 seconds.
Old 08-16-2007, 11:06 PM
csmeance's Avatar
Received 2,004 Likes on 1,424 Posts
if my memory serves me right, the way to do it via gas pedal is to hold it down to the floor while off for about 30 seconds, then to turn the car on and rev to 3k rpm.
Old 06-18-2009, 12:03 AM
AtlM5's Avatar
This is a pretty old thread that I found but...if this method does work, how do you confirm that the ECU is reset?
Old 06-18-2009, 07:54 AM
Full of water...
blkaspec's Avatar
i think you have to turn the key to the II position, then hold the gas for 30sec, but i cant be totally sure...
mada51589
05-03-2022 08:54 PM
02-25-2020 09:57 AM
cycdaniel
12-17-2019 10:58 AM
alan_rich
09-07-2015 11:08 PM
yahelou
09-06-2015 09:12 PM
Quick Reply: ECU reset through drive by wire system?
