Ecm/pcm relation failure code 83-1
Took mt 06 TL to oreilly see if any code would pop up and one did, it was an 83-1 car does drive sporatic, could be nothing, but what could this mean? Is it anything teams related? I hope not. Ecm/pcm relation failure.
it's related to the ABS/VSA system and shouldn't be impacting driveability that much! What issues are you having? It could be a stuck brake caliper or something of the nature if I had to guess
newlux (11-25-2019)
Hi, Did you ever figure out what it was? I am having the same issue. thanks.
I've had a similar issue with this DTC, but I drive a TL-S. What my issue was the VSA modulator power circuit. I double checked the circuit for that system using a wire diagram, and it turned out it was the VSA fuse that was blown. If you had recently hard braked while also honking, you may have blown the fuse(I learned that the power for the horn and VSA are on the same fuse.). Look under your engine hood fuse box and look for a blown VSA fuse. IIRC it was either a 15 or 20 amp fuse. Replacing this fuse fixed the issue for me.
05 acura tl' 84-01
Good evening my fellow acro owners I've purchased a new battery went through all the fuses did everything I possibly could find on the internet I still haven't found out why this code will not let me take it off please help I'm using the fox well NT 510 elite made for Acura
