2007 TL DRL not working
Old May 14, 2015 | 03:19 PM
quantum7's Avatar
I did a search and found a ton of threads regarding replacement of DRL, but I am trying to locate the DRL module on my 2007 TL. About a week ago my dash DRL light popped on and my DRLs are not working. Regular headlight beams are fine only DRLs are off. Checked emergency brake and fuse. Heard that the modules sometimes have solder problems.
I just can't seem to find any information on where to locate the module.
Any help would be appreciated.
Old May 14, 2015 | 05:19 PM
Have you checked your bulbs by chance?
Pretty but go simple then difficult when troubleshooting.
Old May 14, 2015 | 05:24 PM
guitarplayer16's Avatar
I've never heard of the modules going bad.
As suggested, try checking the bulbs?
Then again, I havnt heard of OEM DRL bulbs going out either.
Old May 15, 2015 | 01:27 PM
quantum7's Avatar
yep....bulbs are fine. During my search I found many threads regarding modules and solder issues....reminds me of the HFL problem. Anyway....I can not find anything regarding location of the module so that I can take a look. Various Hondas have the part under different parts of dash or on firewall. Not a vital part for a car with 200,000 miles, but I kinda like them.
Old May 19, 2015 | 07:53 AM
rbailey86's Avatar
I have 180k on my 08 TL and the DRL light is illuminated on dash and I have no DRL
probably the bulbs, but who knows
whats a good replacement bulb?
Old May 19, 2015 | 03:19 PM
quantum7's Avatar
my problem is definitely not the bulbs....checked twice and they are fine....in fact my drl started working again two days ago, then are back off today. Still trying to find info on location of module and a replacement if not too much $....otherwise NBD.
Old May 20, 2015 | 12:10 PM
toantran99's Avatar
Old May 20, 2015 | 12:53 PM
quantum7's Avatar
toantran99
thanks a ton.....I looked everywhere that I had access to and could not find this. Appreciate the help!
Old May 20, 2015 | 01:07 PM
rbailey86's Avatar
let me know if that relay fixes it
Old May 21, 2015 | 10:31 AM
toantran99's Avatar
Originally Posted by quantum7
toantran99
No problem
Old Jun 27, 2015 | 12:20 PM
quantum7's Avatar
Got the part number, but can not find the part: RC - 5102. Acura and the usual auto part stores do not seem to carry and I can not find the equivalent
Old Jun 27, 2015 | 12:35 PM
quantum7's Avatar
nevermind....found the Acura part number....ordered. Will replace next week and hopefully will be all set.
thanks
Old Jun 30, 2015 | 04:42 PM
quantum7's Avatar
Well, replaced the DRL relay....not the problem....still no DRL.
Any other ideas appreciated. Is there a control module somewhere?
Old Jun 30, 2015 | 09:15 PM
truonghthe's Avatar
make sure your car doesn't short out someplace cause the wiring to be burn out instead of replay or fuse. You need to check to see where the power get cut off. sill thing to ask tho but did you check the fuse for DRL?
Old Jul 1, 2015 | 08:08 AM
quantum7's Avatar
fuse is good....first thing that I checked, but thanks for pointing out....I have done stuff like that before and forgot the easy solution first.
I will keep hunting....must be a bad connection somewhere
Old Oct 9, 2017 | 09:08 PM
lukas100lukas's Avatar
Any news
Facing same problem, were you able to fix yours?
Old Oct 9, 2017 | 09:09 PM
where can I get this diagram for 2011 rdx?
Old Oct 14, 2017 | 05:45 AM
quantum7's Avatar
no fix.....must be a bad connection somewhere. On for a month and then off for a month....random. And getting the passenger bulb out is a PITA. Oh well.
Old Dec 10, 2017 | 01:28 PM
dmcoolj's Avatar
Having some electrical issues that I think started with a bad alternator. DRLs not working is one of my issues. Which fuse should be checked?
Old Jan 24, 2018 | 04:59 PM
morrow9's Avatar
I went to the Acura dealership and this is what they put on my receipt. Has anyone tried replacing the entire fuse relay box or anything else they can understand from this picture? They quoted me $960 CAN to fix which I didn't go through with.
Old Jan 25, 2018 | 10:05 AM
peter6's Avatar
First, get multimeter and recheck if that is really the case.
Or go get second opinion from another shop.
Old Dec 16, 2018 | 12:42 AM
hamburglar490's Avatar
Any resolution to this? My DRLs are doing the same thing now. Tried 2 good bulbs, checked fuses, not sure what to do
Old Dec 16, 2018 | 06:04 AM
quantum7's Avatar
Still not working. Must be a bad connection somewhere but I can not track it down. Let me know if you have any success.
Old Dec 17, 2018 | 01:05 PM
morrow9's Avatar
I got another quote from a recommended auto electric technician who said the same thing being to replace with a new underhood fuse relay box assembly. I ordered one from Acura for $432 CDN plus tax and my auto electric technician installed it for an hour of labour. Its been 4 months and I haven't had a problem. Hopefully this thread helps!
Old Dec 17, 2018 | 05:24 PM
MyGuti's Avatar
Holy crap, 432 CAD just get DRLs working again!
I took my DRL bulbs out because I liked the all black look
Old Nov 24, 2023 | 01:25 PM
msl77's Avatar
Screw that I can live without them and the light on dash. Won’t prevent me from passing the state inspection anyways.
Old Nov 24, 2023 | 03:51 PM
thanks for the valuable contribution
Old Nov 24, 2023 | 07:57 PM
Cthulhuy's Avatar
Double check *very* closely. I went crazy trying to solve my problem as well. Circuit, power and grounds were all correct.
hues10
1G RDX (2007-2012)
Sep 7, 2016 03:47 PM
sockr1
Oct 1, 2015 01:31 AM
acurajj
Sep 19, 2015 03:47 PM
spiel08
Sep 7, 2015 08:19 PM
Fadij
Sep 2, 2015 08:31 PM
