Easy Fix for Brake Lights Stuck ON!
Old Nov 7, 2021 | 03:33 PM
csmeance's Avatar
Got back home and noticed my brake lights were stuck on no matter the pedal position! Contorted under the column and pulled off the black plastic cover that hides the stuff above the pedals. Found the brake switch and also the problem!
Originally Posted by knakane
Here's how you do it:
Remove the screw holding in the panel under the steering wheel
Attachment 55182
Pull down on the front of the panel above the pedals - there are 3 clips on the front & the rear of the panel rests on these rubber things
Attachment 55183
Here's what you should see
Attachment 55184
Another view
Attachment 55185
As you can see, when the pedal is pressed, the white thing comes out
Attachment 55186
It should be pretty self explanatory...
1) unplug the wiring harness out of the switch
2) twist out the switch
3) insert the new switch with the brake pedal in it's resting position - slide the switch in...it will make contact with the white plastic attached to the pedal..when the white button thing is pressed in and you cannot push the switch in anymore, twist clockwise & it should lock into place...obviously you want the white button thing to be almost all the way in because when you push the brake pedal, the white button thing will come out and turn on the brake lights etc...
4) plug in the wiring harness
5) test and put the panels back together and you're done!!!
EDIT: I don't know why all my pics are so small..this has never happened to me before...
If you look at the switch in above pictures, the switch touches a WHITE CLIP that is attached to the brake pedal. My clip (blue) came apart and the switch was not operating correctly.
Part is only $3.17 from acura:
https://www.acuraoemparts.com/oem-pa...bC12Ni1nYXM%3D
but almost $10 at local auto stores!!! Next time you buy anything for your car, pick up an extra one as this one was factory from the car almost 17 years old!
here's the autozone one I had to get:
https://www.autozone.com/interior/br...015/343710_0_0
Save yourself some time and energy and have the stupid clip on hand.
Old Nov 7, 2021 | 05:27 PM
You were lucky it did not affect the actual drivability of your car and you made it home to find the annoying problem.
At the clutch inhibiter switch assembly, that very same pedal stopper pad will ruin your day & leave you stranded if it 'crumbles' with age on a manual transmission car.
Old Nov 7, 2021 | 06:03 PM
csmeance's Avatar
That's shitty; maybe we should suggest it as preventative maintenance for clutch and brake pedal bc that would have been a FAT ticket for non-functioning brake lights in a major city.
I was tempted to use some self adhesive pads for the bottom of dinning chairs as a temp fix to save $5 and wait for the $3 on ebay vs $10 from autozone. But decided wasn't worth having an issue a week down the road before the bit arrives. Either way I got it fixed properly. Autozone had the doorman part:
Old Jul 17, 2022 | 05:06 PM
dadsmdx's Avatar
Thanks for this thread. Sure enough I found telltale broken bits in the footwell.
While I waited for the part to arrive, I pulled the 20A "STOP" fuse in the engine bay to stop the bulbs and battery from suffering.
$4 part.
Amazon Amazon
Takes about 1min of total effort. 0 out of 10 on the difficulty scale.
A useful additional reference:
Old Aug 3, 2023 | 08:37 PM
csmeance's Avatar
Clip just broke on the 07; 2 pack is $6.39 now at my local autozone.
Old Oct 14, 2024 | 01:28 PM
jmichaelp's Avatar
Thanks for this. I was going to bed last night & saw some brake lights reflecting off my neighbor's window. I went outside & checked things out. I saw the blue clip shattered on the floor.
I ended up having to pry the panel screw out, it wouldn't back out. I ordered the part from Amazon as that was the least expensive option. However, they bumped the delivery for 9 days from now. So, as a temp measure, I put a bolt in. That seems to be working fine.
knakane
1G TSX Problems & Fixes
Jun 27, 2025 04:04 PM
6MTUA5
Mar 19, 2019 09:57 PM
wpg_tl
Dec 15, 2018 11:07 AM
Bearcat94
Jun 15, 2016 08:32 AM
Carpayment4life
1/2G MDX (2001-2013)
Jul 1, 2015 11:45 AM
