DRL Light on Dash
DRL Light on Dash
Hey I guys, new owner here of a Type-S. I bought this car as a CPO Monday night (10/29). I recently noticed that an indicator light for the DRLs are always coming on. I thought this was just indicating that the DRLs are on, so I ignored it. Then as I'm driving and pulling into a parking spot and see my car reflection on the window in front of the stall, I notice the DRLs are not on where the high beams are. Doing a little research I come to find that the DRL indicator light is actually a warning light meaning there is something wrong with the system. I am pretty disappointed I already have an electrical problem with a car that was certified by Acura. Any suggestions on what to do or should I just take it back to the dealer to get it serviced? Will they charge me? I have an extended non-powertrain warranty that does not mention if this is covered or not. It just says standard maintenance electrical items are not covered such as HID system, fuses, etc.
doesnt necessarily mean something major is wrong. check the fuse, it's under your steering column near the dead pedal. turn your car off before you go pulling fuses tho. i'd also remove your neg battery cable as well.
if the fuse is ok, then it must be the bulbs themself that are bad.
I had the same light come on and up here in CanaDUh , dunno about down there, it indicated I had a headlight out. Do you have low beams at all or any DRL?
Mine came on right after I changed up to a brighter lamp and I didn't have it plugged in all the way.
Now that I think of it .. I think the US is different , mine is an 06 and we have DRLS where in the US they had fogs on that spot. Anyway .. check to see if your DRLs are working .. up here is 1 goes out they both shut down.
Start the car .. shut off the lights and with the e-brake off look to see if the DRLs are on ... if not .. look in the manual and see how to change them .. usually 1 will be out shutting them both off.
FYI... not sure if the DRL's that you have are aftermarket and may have been switched out by previous owner but if so... this might be the reason since there has been cases when the replacement DRL harness w/fuse does not work and the light in your console will stay on. It does not mean anything is wrong, it's just stays on...
Since you just bought the car it should still be under the dealers warrany, which is usually 3 months. On my 350Z, the window motor went out and they replaced it free.
Welcome to AZ! Register it at www.myacura.com and store your Navi and Radio codes there for safe keeping. If you’re in Canada then go here:
https://www.myacura.acura.ca/myAcura...ToLoginPage.do
mada51589
Jan 9, 2025 04:40 PM
Rob144
Sep 21, 2015 08:18 AM
Greengecko
Sep 16, 2015 08:19 PM
