DRL Light on Dash
Old 11-01-2012, 03:28 PM
2022 MDX Advance
K_Squared's Avatar
DRL Light on Dash
Hey I guys, new owner here of a Type-S. I bought this car as a CPO Monday night (10/29). I recently noticed that an indicator light for the DRLs are always coming on. I thought this was just indicating that the DRLs are on, so I ignored it. Then as I'm driving and pulling into a parking spot and see my car reflection on the window in front of the stall, I notice the DRLs are not on where the high beams are. Doing a little research I come to find that the DRL indicator light is actually a warning light meaning there is something wrong with the system. I am pretty disappointed I already have an electrical problem with a car that was certified by Acura. Any suggestions on what to do or should I just take it back to the dealer to get it serviced? Will they charge me? I have an extended non-powertrain warranty that does not mention if this is covered or not. It just says standard maintenance electrical items are not covered such as HID system, fuses, etc.
Old 11-01-2012, 03:31 PM
BANNED
SharksBreath's Avatar
Received 2,885 Likes on 1,784 Posts
doesnt necessarily mean something major is wrong. check the fuse, it's under your steering column near the dead pedal. turn your car off before you go pulling fuses tho. i'd also remove your neg battery cable as well.
if the fuse is ok, then it must be the bulbs themself that are bad.
Old 11-01-2012, 04:42 PM
Jesstzn's Avatar
I had the same light come on and up here in CanaDUh , dunno about down there, it indicated I had a headlight out. Do you have low beams at all or any DRL?
Mine came on right after I changed up to a brighter lamp and I didn't have it plugged in all the way.
Now that I think of it .. I think the US is different , mine is an 06 and we have DRLS where in the US they had fogs on that spot. Anyway .. check to see if your DRLs are working .. up here is 1 goes out they both shut down.
Old 11-01-2012, 04:45 PM
2022 MDX Advance
K_Squared's Avatar
I have low beams on auto and they come on when it's dark. Just no DRL for the high beams.
Old 11-01-2012, 04:55 PM
Jesstzn's Avatar
DRLs should be on any time the headlights aren't.
Start the car .. shut off the lights and with the e-brake off look to see if the DRLs are on ... if not .. look in the manual and see how to change them .. usually 1 will be out shutting them both off.
Old 11-01-2012, 05:30 PM
ilanboy102's Avatar
FYI... not sure if the DRL's that you have are aftermarket and may have been switched out by previous owner but if so... this might be the reason since there has been cases when the replacement DRL harness w/fuse does not work and the light in your console will stay on. It does not mean anything is wrong, it's just stays on...
Old 11-01-2012, 09:37 PM
LoveMyTL-S's Avatar
Since you just bought the car it should still be under the dealers warrany, which is usually 3 months. On my 350Z, the window motor went out and they replaced it free.
Welcome to AZ! Register it at www.myacura.com and store your Navi and Radio codes there for safe keeping. If you’re in Canada then go here:
https://www.myacura.acura.ca/myAcura...ToLoginPage.do
Old 11-01-2012, 09:56 PM
truonghthe's Avatar
Received 1,692 Likes on 1,307 Posts
if you bought it as CPO then toss it to the dealership and have them deal with it.
Old 11-01-2012, 10:39 PM
makk's Avatar
Re-solder the burned contacts inside the DRL control unit. Common issue since they were mandatory here in 1990.
Old 11-02-2012, 03:12 AM
WestCoastin31's Avatar
I'm pretty sure that most states mandate that vehicles purchased from a dealership are supposed to be guaranteed for at least 3 days... sometimes even a month for any defects or malfunctions. Especially a CPO. Don't quote me though, I remember reading a plaque at a car dealership a few months ago that said something like this.
Old 11-02-2012, 03:58 AM
'07 TL Type-S
Healingduck's Avatar
I would think the previous owner might have just pulled the fuse because they didn't like the DRL's. Like SharksBreath said, start there.
Old 07-30-2013, 02:15 AM
4th Gear
jrdelviento's Avatar
I have same issue, but I'm wondering if previous owner used wires for hid foglights, fuse is good now ill check bulbs
Old 12-17-2015, 03:43 PM
DevtypeS's Avatar
My drl not working too and I have a 08 bulbs good relay good fuse good smh
mada51589
05-03-2022 08:54 PM
Rob144
09-21-2015 08:18 AM
Greengecko
09-16-2015 08:19 PM
JnC
09-11-2015 06:06 AM
Fadij
09-02-2015 08:31 PM
Quick Reply: DRL Light on Dash
