Driver's Door Window Won't Auto Close or Open
Head a da Family
When I hit the power window switch to the 2nd position, it only opens or closes while I hold the switch. Meanwhile, the passenger door window works as it should. Do I have to replace a switch?
Registered but harmless
Received 1,149 Likes
You should try the auto window reset first. It's in the manual, but summarized as:
Courtesy of princelybug in the thread @ https://acurazine.com/forums/3g-tl-problems-fixes-114/automatic-window-feature-not-working-758028/.
If that doesn't work, check post #7 in that thread.
If that procedure also fails, buy a new car.
Keep your finger depressed fully on the window switch the whole time you roll down the window. After it is fully down, keep your finger on the switch fully depressed for 2 seconds.
Then, do the opposite when you roll the window up. Keep the switch fully lifted up while the window rolls up, and for an extra 2 seconds after it is fully closed.
Now, try the auto up/down feature and see if it works.
rockyboy
08-04-2024 10:35 AM
ahsm
09-09-2015 08:35 AM
