driver window squeek
Old Jul 9, 2006 | 01:39 AM
RJANACONDA's Avatar
Registered TL Lover
Question driver window squeek
the driver side window make a high pitched sqeek when i roll it down it used to only happed once in a while but now it is more frequent/louder i dont know if its the motor what does anybody know of a way to fix this?
Old Jul 10, 2006 | 02:32 PM
subinf's Avatar
One on the right for me
does it make the sound the entire way down or only at certain points? maybe the window needs to be cleaned, though from what you describe it sounds like maybe the motor is starting to die out.
Old Jul 10, 2006 | 10:49 PM
athlon03's Avatar
i got the noise on the passenger side
Old Jul 12, 2006 | 12:36 AM
kh7085's Avatar
4th Gear
I had this problem before. I went to Acura Dealer three times but they didn't find any problem. One day I found and realized the strange sound from. Because of the passange side mirrior loose when I driving the mirrior is shaking but I couldn't know it was mirrior I was thinking it was window borken or something. You can try to push your mirrior or you can ask Acura dealer to take look. After I told Acura dealer and they fixed the problem and also check driver side mirrior.
Old Jul 13, 2006 | 09:27 AM
RJANACONDA's Avatar
Registered TL Lover
when it does do it it varries sometimes its only part way other times its the whole way and sometimes it dosent do it at all then it will stop doing it for a few days and then be constant then intermediate
Old Jul 13, 2006 | 09:31 AM
RJANACONDA's Avatar
Registered TL Lover
this isnt a rattle/shake its more of a high squeal like someone peel-out with bicycle size tires for a shourt peroid
Old Jul 13, 2006 | 10:19 AM
King of Pain's Avatar
When I had my windows tinted awhile back the installer noticed the same noise on the front passenger side. While he had the window seals off the door we looked inside and noticed that there is a pulley wheel that works the up/down cable. This pulley gets stuck sometimes and does not move. This causes the cable to rub against the pulley as the motor works the window up and down.
I just need to go to the dealer and convince them of the problem so they can fix it.
Old Jul 13, 2006 | 10:27 AM
RJANACONDA's Avatar
Registered TL Lover
maybe i have the same thing
le^2
Mar 17, 2026 05:06 AM
Nate_808
3G TL Photograph Gallery
Oct 9, 2015 07:24 PM
c1souk
Sep 28, 2015 11:20 AM
spoiler900
Sep 23, 2015 04:41 PM
