Driver side airbag leak near window...HELP!
Old Oct 10, 2024 | 12:45 PM
wildephoenix's Avatar
Unhappy Driver side airbag leak near window...HELP!
Hello guys, I have a 2008 TL base model.
Over past few months, I've noticed water in the area of the photo(1st photo) driver's side.
I bought a snake/line cleaner from Amazon and cleaned out the hole (in sunroof). Water is draining out to the bottom(2nd photo)
of the car. I also did a test of taping (3rd photo) all around the sunroof and going thru a carwash/spraying with hose. The leak still accumulates and occurs.
What else could this be? Thanks for any advice.............
Old Oct 10, 2024 | 02:52 PM
why don’t you pop off the a pillar cover to see what’s actually leaking?
Old Oct 10, 2024 | 03:00 PM
thoiboi, are there any steps to doing that? I didn't want to mess anything up. Thanks
Old Oct 10, 2024 | 03:31 PM
Use a flat head to pry off the small square and it should expose a bolt that you can remove
Or once it’s pried up , it rotates, i forget which one. Should be obvious once you pry it though
Old Oct 10, 2024 | 03:32 PM
Thanks! I am guessing I need to disconnect the battery? So airbag won't go off
YT is my friend:
hxxps://youtu.be/ocEawuJJcEU?feature=shared
Old Oct 13, 2024 | 03:08 PM
So I took the pillar off...Pretty easy as you described. I did disconnect the battery as well.
I can see the water stains (2 prominent areas) and above here I circled in RED. Can I use silicone/sealant on that area to seal it? Any suggestions?
Old Oct 13, 2024 | 05:32 PM
Old Nov 19, 2024 | 06:40 AM
My issue is exactly the same as what the guy had in the video. Sunroof drains cleaned out...Was focused on internal/pillar since that's where leak was.
I clear taped over that whole external area to test. No leaks after spraying down. Time to repair.
adamhodge
6G TLX Problems & Fixes
Aug 20, 2025 06:37 AM
mjhrrsn8888
2G CL Problems & Fixes
Jan 24, 2024 01:40 PM
Kinuto
Nov 29, 2022 07:41 AM
ATL_TL_2008
Feb 26, 2020 12:52 PM
VanyDotK
4G TL Problems & Fixes
Nov 5, 2014 02:40 AM
