Drain plug gasket
Old 04-25-2012, 09:03 PM
4th Gear
OhioTL's Avatar
Drain plug gasket
Is there a good place to buy these in bulk? 095-015.1
I've used these on an accord, pilot and TL. went to 3 parts stores tonight and they're all out of stock. Any thoughts?
Old 04-25-2012, 10:20 PM
con5tant's Avatar
i usually buy them here along with the oil filters (pack of 6)
http://www.handa-accessories.com/tl04.html
6-pack of washers $1.31
Old 04-26-2012, 06:32 AM
gideon's_test's Avatar
$6.99 for 5 crush washers, shipped: http://www.kseriesparts.com/cr/HON-94109-14000.html
Old 04-26-2012, 10:02 AM
Dogmatic Dinosaur
jda123's Avatar
I put 450K miles on an accord and used the same crush washer the entire time. Both of my TLs have the original ones on them. They will leak if they need to be replaced... which may never happen.
Old 04-26-2012, 10:39 AM
con5tant's Avatar
lololol holy shit what a rip off!
ftl
Old 04-26-2012, 11:35 AM
ftl
Did you check to see what the shipping was for the link you posted? I did. It was $10, making the total for the ones you posted $11.31, which is nearly double. Going to the dealer is the best option.
Old 04-26-2012, 12:08 PM
con5tant's Avatar
well, maybe it depends on where you live. I always buy the washers with the filters and they ship to me for like $5 for both
Old 04-26-2012, 12:09 PM
LoveMyTL-S's Avatar
I got mine from the dealer. But now I use a drain valve and never have to remove the plug. Problem solved.
Old 04-26-2012, 08:51 PM
4th Gear
OhioTL's Avatar
thanks for your thoughts. I tried reusing washer once, it leaked, tightened a bit more, still leaked so I've been buying new each time I change oil.
Mike734
12-10-2021 01:25 PM
ITSJESTER
17
12-06-2018 02:29 AM
MetalGearTypeS
08-29-2016 08:28 PM
InFaMouSLink
10-27-2015 06:52 PM
Joe Avesyan
09-29-2015 03:57 PM
Quick Reply: Drain plug gasket
