Doors lock/unlock while driving, PLEASE HELP!!!
Old May 15, 2009 | 06:57 AM
kevjam's Avatar
6th Gear
My wife drivers our 04 Acura TL. She is complaining that when she comes to a complete stop at a red light, stop sign, etc... and starts to move again the car will relock (arounf 10-15mph). I thought it might be a key fob issue but we tried the other fob and that didn't solve the problem. Any help would be greatly appreciate. If I have to take it to a dealer, does anyone know how much this would cost to fix? Thanks for your help in advance.
Old May 15, 2009 | 07:56 AM
Trew's Avatar
There is a setting in the MID that turns this feature on/off. Try turning it off and see if it fixes the problem.
Old May 15, 2009 | 12:36 PM
zeezz's Avatar
Team Anthracite Webmaster
is she unlocking the doors beforehand? or is just trying to 'relock' even though they are already locked.
Old May 16, 2009 | 06:00 PM
Etohprn247's Avatar
KoolKatz..
Its on auto lock >10mph, take that off and if still samething prolly driver actuator going bad....
Old May 19, 2009 | 06:16 AM
kevjam's Avatar
6th Gear
Thanks for everyone's help. I changed the setting in the MID and it worked fine for a two days. Now I'm getting the common problem of the driver's side door not locking with the key fob. It doesn't even lock when she manually presses the button while in the car. I assume I should start by changing the actuator in the driver's side door. Is that a correct starting point?
Old May 20, 2009 | 08:06 PM
Etohprn247's Avatar
KoolKatz..
Changing the actuator will prolly fix the problem I had similar simptoms and replacement of the actuator DID fix the problem, I bought extra OEM actuator from dealer $40 but didn't install or use $25 shipped if your want it. holla
GL
Old May 21, 2009 | 12:16 AM
240sx acura tech's Avatar
acura master tech
door switch. if your in the car and lean on the door and it unlocks.
rockyboy
Aug 4, 2024 10:35 AM
Feb 25, 2020 09:57 AM
tman570
Jun 11, 2019 07:56 AM
ahsm
Sep 9, 2015 08:35 AM
3.5RLv-tec?
1/2G MDX (2001-2013)
Sep 7, 2015 11:00 PM
