Door handle cover help
Old Nov 29, 2011 | 08:53 PM
gamepoint's Avatar
I think I posted this in the wrong category earlier
All but the driver side door handle little plastic covers have fallen off my car (plastic piece right next to handle) So Ive decided to replace them including the driver door because its a little loose as well. The parts are cheap but I cannot figure out how to buy the Right Front cover. on acurapartswarehouse.com there is Left front, Left rear, Right rear but no Right Front. any advise?
Old Nov 29, 2011 | 09:00 PM
swoosh's Avatar
takin care of Business in
here is the DIY:
https://acurazine.com/forums/3g-tl-2004-2008-93/shaved-door-lock-mod-part-source-3g-garage-e-022-a-585256/
https://acurazine.com/forums/3g-tl-2004-2008-93/anyone-consider-mod-garage-e-022-a-552284/
its in both these threads.....
you can also replace it with the handle cover from the other door....called the "shaved" look....
Old Nov 29, 2011 | 09:19 PM
Bearcat94's Avatar
AZ Community Team
There is also a TSB with the remove/replace instructions.
Go to this page: https://acurazine.com/forums/3g-tl-2004-2008-93/3g-tl-technical-service-bulletins-tsbs-3g-garage-j-016-a-613659/
Follow the instructions at the top of Post #1, then access this TSB Link further down the page: TSB 07-043: Outer Door Handle Extension Falls Off
You can't find a "Right Front" because it's the same as the "Right Rear". If you look on this parts page - which is the FRONT Door Locks - look at item #32; it says, "R RR".
http://www.acuraautomotiveparts.org/...s=&view=normal
Rears are here, Items 22 & 33: http://www.acuraautomotiveparts.org/...s=&view=normal
Old Nov 30, 2011 | 11:12 PM
gamepoint's Avatar
thanks for help. I will order the parts today
Old Nov 30, 2011 | 11:16 PM
swoosh's Avatar
rockyboy
Aug 4, 2024 10:35 AM
tman570
Jun 11, 2019 07:56 AM
Sep 17, 2015 09:01 PM
hand123
Sep 10, 2015 09:29 AM
eastcoastguy
Sep 9, 2015 09:59 PM
