Does anyone know why this happened?
Old Aug 5, 2011 | 08:37 AM
**WhItE-aNgEl**'s Avatar
Hey everyone, does anyone else have these scratches in the circle under there door handles? I have them on all four doors. Is there anyway to remove them without having to paint? And any clue why this happens? Here are some pics
Old Aug 5, 2011 | 08:43 AM
dont have anything in your hands, while you open your doors.
Old Aug 5, 2011 | 08:47 AM
Andy Tsang's Avatar
Take a buffer and buff it out, I did it on my dad's car.
Old Aug 5, 2011 | 08:49 AM
I don't wear rings or any jewelry. I don't open my doors with anything on my hand. Is there anything that will remove this?
@justinspace thanks for fixing my pics.
Old Aug 5, 2011 | 08:50 AM
Like, andy said, you can take a buffer and remove them.
Is there a way to remove the handles? My buffer won't fit thru there.
Old Aug 5, 2011 | 08:55 AM
Thomasv's Avatar
hand buff it dood... lol a buffer is only a device you could use for convenience...if you cant get it in a tight area you gotta go all ninja on it...wax on...wax off... cmon kemosabe!
Old Aug 5, 2011 | 08:58 AM
Dont think by hand will work....
you need the machine, because hand cannot possibly rotate at 2-3k rpm, much less at 6,000 rpm.
Old Aug 5, 2011 | 09:00 AM
Turbonut's Avatar
From fingernails hitting the paint when grasping the door handle. Take some cleaner wax with a cloth and polish and you can hold the handle outward to gain some additional room.
Old Aug 5, 2011 | 09:02 AM
jspagna1's Avatar
The Sicilian
I use Turtle Wax Bug & Tar remover and it gets most of the sctratches off unless their really bad.
Old Aug 5, 2011 | 09:23 AM
Bearcat94's Avatar
AZ Community Team
This. you could also use some compound/polish (Scratch-X, for example) if the cleaner wax isn't aggressive enough.
When done, put a wax or sealant finish coat on.
Probably need to repeat every 6-months or so.
Old Aug 5, 2011 | 09:59 AM
imj0257's Avatar
Q('.')=O
I have the exact same thing. And I don't wear jewelry and don't use my key to open the door. Must be my fingernails .
Old Aug 5, 2011 | 10:17 AM
Trunk Monkey's Avatar
Coolest A-zine Member
Eh..all you're doing with those products is filling in the scratches. You'll likely need a PC to buff that out
Old Aug 5, 2011 | 10:44 AM
I was thinking it might be from the snow remover brush.
Old Aug 5, 2011 | 10:45 AM
^you brush underneath the door handles?
Old Aug 5, 2011 | 10:55 AM
Majofo's Avatar
Clean underneath your nails, gross.
coykiam's Avatar
lol Just...
I have most of mine in the 2 front doors and it is most likely from fingernails. Waxing it helps get some of them off.
Old Aug 5, 2011 | 11:05 AM
Yeah i get these huge cluncks of ice that won't let me open the door. And I don't have long nails to be able to do that kind of damage. It has to be the snow brush. I'll polish it thus weekend depending on the weather.
SidhuSaaB
May 30, 2020 12:40 AM
SilverJ
4G TL Problems & Fixes
15
Oct 13, 2015 05:14 PM
Houston
Oct 8, 2015 01:27 AM
xsilverhawkx
Oct 5, 2015 11:00 AM
