Dies when idling
Old Mar 10, 2019 | 04:23 PM
Ricardo Casiano's Avatar
Dies when idling
I have a 2006 Acura TL. My starter is brand new, my alternator is brand new, and the hfl box is as remove from the previous owner and I change my car battery TWO TIMES!!!! What can be draining my car battery or what should I do?
Old Mar 10, 2019 | 08:31 PM
peter6's Avatar
1. To track down the issue you will need to have ampmeter or ampclamp.
If you don't have one, get any that has decent accuracy and will work with DC (as some cheaper ones can measure only AC current).
I bought this one a while back:
Amazon Amazon
and its been working fine.
Then you put that around battery cable and look for current. If it's above 0.2A when car was sitting for a while, door closed, no key in the ignition, then you have a parasitic draw.
To find it, pull fuses one by one, until current measured by the clamp drops. If you find that fuse, then you simply go to service manual to find out what is on that circuit.
When you know, you can keep checking other things, mostly by disconnecting them, but finding the fuse is the first step.
2. Did you try taking AC compressor cluch relay out? It's second common draw in our cars.
quanaman
Sep 25, 2013 04:29 AM
Matthew22
Apr 10, 2013 08:19 PM
ch0wch0w
Jan 7, 2012 05:50 PM
