Did i put too much oil
Hey guys its been a while, i had a day off today so i decided to flush my power steering fluid and change the oil+filter. The last couple times everything went smoothly and the oil level was fine but this time i think i overfill the engine. On the oil dipstick i barely had any oil after letting it run for 5 minutes so i added about half a quart then decided to go back home. The new dipstick level im getting is the oil covering the ''rca'' letters but just under the second dot. Its above the the square with lines where i usually have it. Do i need to remove some excess oil or is it fine if i let it that way ?
You'll be fine, your engine will burn the extra off
nah bruh.. just open up the drain bolt a bit until oil starts to seep out. Don't back it out all the way. #protip
Then measure what comes out.
The following 2 users liked this post by Majofo:
EvilVirus (11-16-2017),
justnspace (11-14-2017)
2. remove dip stick, put mouth around fill hole, suck as hard as you can until .5Qt comes out
3. Start your car and slam on the pedal to redline and burn off the extra oil.
3 options.. use your common sense
Amateur
Just puncture the oil filter
Like with a bullet
Like with a bullet
I've done it with ATF when I overfilled. Just put an oil pan under the plug, remove it for a minute, then put it back. Yeah, get's ATF all over your hand but if you're wearing some nitrile gloves it's not a problem.
got them nurses mixed up :fail:
Oh damn.. you weren't present when she took one for the squad.. too bad.
#allholesmatter
#allholesmatter
