Dent in Rear Fender Crease...
Old Jan 16, 2010 | 01:07 PM
barnash22's Avatar
This was done to my car in a Parking lot even though I park my car as far away from others to avoid door dings and the such. Guess I did not park far enough away.... A body shop told me it would be over $600 to fix because it located on the crease about an inch from the lip of the fender. Does anyone know if a dent repair shop (dent pro) can fix this? Or should I avoid those places all together... Any help would be appreciated.
Old Jan 16, 2010 | 09:30 PM
LiquidLunch's Avatar
The dent is too big and deep for PDR (paintless dent repair). This will need body work and paint.
Old Jan 17, 2010 | 08:41 AM
Majofo's Avatar
damn that sucks.. you can try to push it out but I doubt it'll be 100%.
Old Jan 18, 2010 | 03:26 AM
xmrgoodcatx's Avatar
I would consult with a paintless dent removal tech. I think if biggier then 5 inches they will recommend body work. The part that sucks is the crease. They maybe able to pull it, but you might see slight waves and the crease may not be as smooth. If they can it will be significantly less then 600.
My Mom's SUV had a softball size dent on the rear quarter and it was on a crease not as defined as where yours is, but it was pulled. You can't really see it, but you have to know where to look and only can see it an angle. The crease came out fine as well. No one that knew there was a dent previously took notice either, couldn't even tell.
Old Jan 18, 2010 | 08:47 AM
Jesstzn's Avatar
Definatly consult the PDR .. they took a nasty one out of the top of my front fender and no traces.
Old Jan 18, 2010 | 10:40 AM
barnash22's Avatar
Thanks guys.... I Live in Las Vegas so I know there are PDR or Dent Pro's in the area.....
Old Jan 18, 2010 | 11:14 AM
pchesnut's Avatar
Had the same dent in my 06 TL, cost about 400-600 to get it reworked and painted. No way it could be rework via the dent puller magic since it was on a crease.
Good luck
Old Jan 18, 2010 | 05:00 PM
barnash22's Avatar
Thanks Pchesnut.... Its the truth, every place wants around 500 bucks..... horrible.
Old Jan 18, 2010 | 08:54 PM
jbacura's Avatar
Do not go to the body shop some of the Paint less dent remover guys work some magic. I swiped the whole side of my car against the garage divider, and a body shop quoted me $1500. They also recommended me consulting with a PDR remover, and I'm glad i did. It cost me $250 and you can not tell whatsoever there was ever damage on the side of the car. The only thing i notice is at certain times of the day you can notice a little more orange peel in the paint where the dents were pulled out. Trust me in that Picture you have that would nothing for them.
Old Jan 19, 2010 | 02:36 PM
2Morrow's Avatar
Driver Mod
Yeah, some asshole did something similar to me last weekend in SF.
F-in Pissed !
Old Jan 19, 2010 | 03:26 PM
subinf's Avatar
One on the right for me
Looks a little too big for dent removal but it never hurts to ask
Old Jan 19, 2010 | 07:44 PM
barnash22's Avatar
Its raining so hard here in Vegas the Dent People wont even roll out to my house..... Love the customer service of some shops in LV....
Old Jan 21, 2010 | 05:25 AM
UplandTLsleeping's Avatar
Addicted to Speed
what ever happened to do it yourself. I had an estimate of 5500.00 , I went on learned the basics. Did the repairs myself and saved thousands.
Old Jan 21, 2010 | 08:29 AM
Jesstzn's Avatar
You'll never DIY unless your skilled with the full body shop capabilities on a color like his. Even then shops have trouble matching colors at times.
Old Jan 24, 2010 | 06:29 PM
pchesnut's Avatar
I was pretty bent when I got the dent in my 06 but it sure was nice when I got it back repaired. I diligently park in what my kids cal the "Acura Approved Parking" way out in the back of the lots but still got whacked in the same place. Really Sucks!
Good luck.
Old Feb 15, 2010 | 09:55 AM
nspec_ya4's Avatar
Regional Coordinator (Texas)
what car is this exactly? if its a 3gen TL then PDR will not work on it that good, barely.
Old Feb 15, 2010 | 09:58 AM
Jesstzn's Avatar
And why is that?
Old Feb 24, 2010 | 07:39 PM
subinf's Avatar
Why? That doesn't make any sense.
Old Feb 26, 2010 | 03:43 AM
SleekSilverTL's Avatar
Barnash... any updates on your dent repair.. could definitely use some advice. Unfortunately I recently noticed a similar dent on my fender well, covering the crease, but its much smaller, probably around an 1.5 inch in diameter.
Old Mar 11, 2010 | 11:18 PM
nspec_ya4's Avatar
Originally Posted by Jesstzn
And why is that?
the reason why is because that specific area on 3g TLs is filled with glue and it double panel for the most part. you can try glue pulling it to make it look smaller, but you cant put a tool behind it. Any thing from that point and lower i believe.
Old Mar 12, 2010 | 10:43 AM
2Morrow's Avatar
Driver Mod
^^^ Engrish !!!
"English m-f'er ! Do you speak it !!??" - Jules, Pulp Fiction.
Old Mar 12, 2010 | 11:30 AM
Majofo's Avatar
you mean you need engrish transration.. let me see if I can help:
In English:
Engrish Transration:
In 3g TLs that the area where specifies the adhesives and why with it coming to fill in two times commission most is a because, reason. You sees in it, being smaller and in order to make will be able to attempt the adhesives which pulls it, you who inclination fall but put the tool on rear of it. Believes what kind of thing from the point and lowers.
Understanding now is useful?
Old Mar 12, 2010 | 12:34 PM
2Morrow's Avatar
Driver Mod
Hiralious !
Old Apr 4, 2010 | 08:12 PM
twistdtl's Avatar
7th Gear
That will never come out with PDR guys!
TLDude876
Dec 28, 2016 03:18 PM
o8 ENVII 8o
Nov 30, 2015 04:23 PM
usdmJON
ILX Tires, Wheels & Suspension
Nov 13, 2015 07:06 PM
AZuser
Sep 17, 2015 10:15 AM
Sep 4, 2015 08:03 AM
