Delay in going into reverse normal ???
Old Feb 21, 2009 | 07:51 PM
jmoney2001's Avatar
is it normal to have a couple of sec of delay when shifting into reverse when car is warm.???? please keep in mind that i just bought the car and didn't come with a dip stick lol. you guy think it may just be my fluid it shift fine other than reverse. umm if i find one were do i add some tranny fluid???
Old Feb 21, 2009 | 07:56 PM
vinnier6's Avatar
its normal...i have had my car since new and it deos it...
Old Feb 21, 2009 | 08:22 PM
jmoney2001's Avatar
you sure?? i have owned many acura like the rl and hondas and they engage quickly when in reverse. the delay comes only when warm
Old Feb 22, 2009 | 08:37 AM
perlztt's Avatar
kPPPPPPPPPPPPP)
Old Feb 22, 2009 | 10:51 AM
jmoney2001's Avatar
ummm ???????
Old Feb 22, 2009 | 11:31 AM
01tl4tl's Avatar
get a trans dipstick from junkyard or dealer
you can add fluid thru the dipstick hole if needed
read owner book for proper warming drive and checking procedure
Old Feb 22, 2009 | 11:50 AM
Majofo's Avatar
a couple of seconds? that's not right. Give us more info, year / mileage... I find it strange that there was no dipstick. It's like the dealer doesn't want to smelling or looking at the ATF. Did you buy this from Acura / Lemon Lot / Private Party?
Old Feb 22, 2009 | 11:54 AM
Majofo's Avatar
Take a look at the tranny case as well and look for signs of a leak. If it's real bad the leak will leave marks down your chassis / exhaust.
Old Feb 22, 2009 | 01:10 PM
jmoney2001's Avatar
35k miles carfax proves. tl drives fine in forward gears but it just lags when the car warms up when shifting into reverse. bought at auction didnt relize no dip stick cuz bought from internet. the dip stick hole is very tiny you sure thats were i fill trany. their is no way. also came with no owners manuel
Old Feb 22, 2009 | 03:26 PM
vinnier6's Avatar
i have the same delay going into forward from reverse too....i have had many hondas and none of them did this, so when i first got the car i was like wtf over...but its normal...
Old Feb 22, 2009 | 04:36 PM
Majofo's Avatar
Carfax and Autocheck only know what's reported. There are a lot of vehicles on the road that have been salvaged or been in wrecks that are not reported because there was no insurance claim. If there is significant lag when shifting to reverse then the hydraulic pressure to your clutch is poor or hopefully it may just be your shift cable but it may more than likely be your servo valve that's engaging your reverse gear which is where the delay is occuring.
Do you notice a lag accelerating / increasing throttle? [eg. hit the gas.. a couple second lag before engaging?]. 35k miles is pretty low but I would do a 3x3 on it. Especially since you don't know how it was driven before you obtained ownership. The ATF dipstick inlet is small and recessed so I would shy away from trying to top off if indeed the fluid is low. I don't know your mechanical intuition but I would take it into Acura or a good tranny shop that specializes in Honda / Acura and have it diagnosed, then get back to us.
Old Feb 22, 2009 | 06:49 PM
jmoney2001's Avatar
nope sorry my problem is from park into reverse. it only does it in reverse gear.
and no when i stomp on the gas it kicks back hard and takes off. all gears are smooth as butter. so it seems that other people are having the same issue? i do feel good about doing the 3x3 just that fluid is so dag expensive. dont want to take it to a tranny shop cuz i know they will want to rebuild it. will low tranny fluid cause this same issue?
Old Feb 22, 2009 | 06:58 PM
Majofo's Avatar
correct me if I'm wrong but low fluid would decrease the hydraulic pressure causing a lag before gear engages but I think it would have a similar effect when going into drive. You may want to adjust your shift cable and see if that helps. Z1 is expensive.. especially for when doing a 3x3.. I would at the minimum check the ATF condition but if the throttle is spot on, then I doubt it's sludging.
Old Feb 22, 2009 | 07:12 PM
jmoney2001's Avatar
well remember that when i first drive it when cold it does not do it. but regardless iam going to do the z1 fluid change anyways. i just wanted to know if anyone else experianced my same issue to see if i needed to throw on a new tranny
MrHeeltoe
20
Feb 23, 2023 01:54 PM
SidhuSaaB
May 30, 2020 12:40 AM
MrHeeltoe
Sep 29, 2015 10:43 PM
MrHeeltoe
Sep 28, 2015 05:43 PM
thegipper
Sep 28, 2015 01:01 PM
