Debadging problems!!!
Old Feb 4, 2010 | 10:03 PM
henrylo's Avatar
Moding time
After debadging the "acura" and "TL" emblem, there is a leftover print on my car. what should i do to take that out. let me know. thanks
Old Feb 4, 2010 | 10:06 PM
pearlite TL's Avatar
mild soap and water does the trick!
Old Feb 4, 2010 | 10:07 PM
apnorm's Avatar
are you talking about the glue residue? Some simple soap and water should do it.
Old Feb 4, 2010 | 10:58 PM
Phambam12's Avatar
Phmbm12
goo gone
Old Feb 4, 2010 | 11:02 PM
spicynoodle116's Avatar
Newb
I used rubbing compound, got rid of the print/shadow whatever you wanna call it. it have other good uses too, so buy it if you dont have it.
Old Feb 4, 2010 | 11:44 PM
Timb227's Avatar
Fear and Loathing in my
bug and tar remover.
Old Feb 5, 2010 | 12:16 AM
BLACKURA_NY's Avatar
I have car ADD
it has so many uses. rubbing and polishing...
i would start with polishing first... if that doesnt work, then go with rubbing. rubbing is a bit more abrasive
Old Feb 5, 2010 | 12:26 AM
Newb
i use it on my car often because theres a lot of oxidization when I got the car. It is 5 years old after all. At first I bought it because of the debadge, then I start using it on the door handles, under the side markers, anywhere else that looks dirty.
Old Feb 5, 2010 | 01:11 AM
tl_dinhsum84's Avatar
alchol will wipe it right off
Old Feb 5, 2010 | 07:49 AM
KN_TL's Avatar
I used goo gone and scratch-x. I found it looked like it was gone, but when the dust settled on it I could see the shadow. It took me a couple of tries with both.
Old Feb 5, 2010 | 07:54 AM
wasupdog's Avatar
My Garage not
bug and tar remover with a hairdryer and it rolls right off.
Old Feb 5, 2010 | 08:12 AM
dave_ramkumar's Avatar
2011 ZCP E92 M3!!
Originally Posted by Phambam12
goo gone
+1
Old Feb 5, 2010 | 08:46 AM
Jesstzn's Avatar
Be very careful when venturing here .. "Rubbing Compound" is a very broad term and has got a lot of people in trouble .. especially the TW stuff.
Your better off to try something like ScratchX on a soft cloth and use a little patience.
I have repaired more than one "Rubbing Compound" adventure and its not cheap.
Here is one example of someone taking the "Rubbing Compound" advice;
Old Feb 5, 2010 | 10:09 AM
candrews's Avatar
WD40 does the trick and will not leave any marks like polishing compounds or goo-gone...
Old Feb 5, 2010 | 10:10 AM
Crestwood1001's Avatar
I just used a good wax. Clean it up and wax it, its semi abrasive so it takes the marks right out.
Old Feb 5, 2010 | 10:13 AM
Jesstzn's Avatar
What wax .. it would help a lot if you guys were a little more specific in your suggestions.. I know lots of "good" waxes and most aren't abrasive.
Old Feb 5, 2010 | 10:37 AM
dopefedz's Avatar
I used googone, alcohol, soap and water and the outline would not come out. I had to pull out the Porter Cable and buff it out.
Old Feb 5, 2010 | 01:11 PM
It not exactly abrasive, but all waxes are a little. I forget the name its in the bright orange bottle. Love the stuff
Old Feb 5, 2010 | 01:29 PM
BuffBakerGA's Avatar
Bug and Tar remover for the glue and McGuiars deep crystal polish to bring the colors back...
Old Feb 5, 2010 | 01:40 PM
rwest311's Avatar
8th Gear
That would be Nu Finish.....love that stuff!!!
Old Feb 5, 2010 | 01:58 PM
Dan1629's Avatar
Registered Member
3m hand glaze works really well in alot of situations, might help you out
Old Feb 5, 2010 | 03:32 PM
jspagna1's Avatar
The Sicilian
I have used the bug & tar remover and I have also used Goof-off.
Be careful & patient when using any of these products. Use at your own risk.
http://www.azpartsmaster.com/Product...l__GOF150.aspx
Old Feb 5, 2010 | 04:15 PM
NOTSKERDD's Avatar
I got a cotton ball w/ wd-40 and taped on for 5 minutes. Came off w/ no traces of glue left. Then i used some spay on wax and it looks perfect.no "ghost" letters left either....
Old Feb 5, 2010 | 05:04 PM
Nu Finish! Thats what it is haha, and what color are you guys doing this on? It came off no problem on my WDP
Old Feb 8, 2010 | 01:12 PM
blkonblk05TL's Avatar
from all the times i've done this..
goo gone and some decent wax. use a few coats if necessary and some decent elbow grease and you'll get that paint blended.
fwiw i wouldn't use very corrosive chemicals or hardcore detailing products for something that is relatively trivial to do in aspects of detailing and such..
Old Feb 13, 2010 | 09:13 AM
henrylo's Avatar
Moding time
i wish someone told me this earier, i used 3M adhesive remover and it literally took some of the clearcoat of car away
Old Feb 13, 2010 | 09:16 AM
Jesstzn's Avatar
How do you know this? ...maybe the area is just hazed from the removal.
SidhuSaaB
May 30, 2020 12:40 AM
Fool
Mar 10, 2016 08:42 PM
12vancover
Oct 16, 2015 12:04 PM
Matthew Purpura
Sep 25, 2015 06:10 PM
MikeJM310
Sep 24, 2015 07:24 PM
