Dealer wants $692 to replace radiator!!!!
I think I need a new radiator for my 06 Ac-rite TL! The acura dealer wants to charge me $692 for the radiator n labor! Is this too much or about right? I think it's too much but I'm open for opinions. Thanks ya'll!
Cause i see da radiator fluid leaking around the hose that leads to the resevoir tank on the radiator. I think it might be the hose to the resevoir but it's been leaking for a while now and the radiator fluid has dried up all on top around the part where the hose that leads to the resevoir tank is. I might go buy a new hose first to save money. It's not running hot or anything but it is definitely leaking.
hates potatoville
Mine did the same thing. Just use a ziptie to tighten it down and cut off the excess of the ziptie. Don't waste your money. Try the ziptie first, if it doesn't work, replace the small hose you can get anywhere for about a buck. Try these first but I know for sure the ziptie will solve it.
Thanks for your help. I bought hose clamps but I think it's the radiator and not the hose now cause i used a cotton swab to wipe around where the hose is attatched to the radiator and it was dry but radiator fluid was leaking under it still. I'm no mechanic so I'm just going by what I think. hahaahhaaa
Hahaahahah. Thats why I asked my fellow acura owners first. I decided that since I already bought the hose clamp for the hose, I might as well use it and it haven't been leaking yet!!!! i think my problem is solved! thank you all for viewing this n helping.
Moderator, can you plz delete this thread. Thnx!
