Dead Driver Side HID Bulb
Hi Acurazine community,
As of the past few months, I have become a proud owner of an Acura TL '04 and loving it! Only real problem that has come up is my driver side HID bulb is out. No warning signs or anything, just dead. Passenger side works still. My question is, is it the actual bulb itself, or the ballast that would need replacing?
That is a good point. Thank you for your response! I will have to try that once it's not 20 degrees out here...
Registered Bunny
Some people mess around through the wheel well to do that stuff, I find that's more trouble than anything. The good way is to take off the bumper, a 10 minutes job once you're used to it. First time takes around 30 at best.
Is it seriously that quick? It seems like it would be so much more of a hassle.
Update for HID driverside bulb
I finally was able to take my bumper off yesterday/this morning. Results are that both bulbs are perfectly fine. Took both headlight units and tried them on each side with both bulbs, swapped HID ballasts, but the driver side will not work. I am pretty convinced it is the bulb igniter. The passenger side igniter looks cleaner I noticed. Like the center of it looks clean where as the right looks actually bubbled a bit like burnt. I am hoping and thinking this is the issue.
Before I start buying parts, I would appreciate feedback. Thoughts?
If you're convinced it's the ignitor, have you tried to switch THAT to the passenger side to confirm?
Don't swap more than one part at a time, that wouldn't do much for troubleshooting purposes.
1. Swap bulbs, check.
2. Swap ignitors, check.
3. Swap ballasts (control unit), check.
Reporting back soon!
Good news! I was able to investigate again and found out that the driver side HID Bulb Socket is bad.
Only thing to do now is to purchase a replacement. Anyone have any recommendations of where to buy one?
Not sure what that means.. bulb socket. You mean the ignitor perhaps?
IGNITER, HID | Genuine Acura | 33129-S2A-J01
rockyboy
08-04-2024 10:35 AM
sockr1
10-01-2015 01:31 AM
