Dashboard cracked...any help??>?
Old Jun 22, 2011 | 04:12 PM
villam10's Avatar
Hello everyone...I'm new to this forum but I have been an acura owner for quite a while...this is my 2nd acura tl....(my current car is a 2004 TL 6sp manual). I'm having the same problem with my current car as I did with my previous one....the dashboard is cracked at several places (mostly on passanger side by airbag)....I called the local acura dealer and I'm looking at $1800 for parts and labor. Does anyone out there know of a cheaper solution??? Both the interior and exterior is in excellent shape...very clean and than you got the cracked dashboard....I'm not sure wheather I'm unlucky or not, but for this to happen with two diff cars...same problem...looks to me like this is a reaccuring problem for the 2004 TL......
Any help would be greatly appreciated.
Old Jun 22, 2011 | 04:23 PM
leedogg's Avatar
RAR
if its already cracked you might be SOL. It cracks because sun/heat dries it up and degrades the plastics. to prevent this from happening: park indoors, get a sunshade, use 303 aerospace (contains sunblock), use a dash cleaner/conditioner regularly (I like poorboys natural interior).
Old Jun 22, 2011 | 04:25 PM
Turbonut's Avatar
Replacement is the only answer unless you want to use a filler on the cracks to which I wouldn't recommend:
https://acurazine.com/forums/3g-tl-problems-fixes-114/cracked-dashboard-04-tl-688828/
Old Jun 22, 2011 | 04:44 PM
lucnex's Avatar
Where Did My Garage Go?!!
I vinlex the shit out of mine, also helps to remove that indentation where the airbag is. Seems like your SOL this time, but I would suggest that (as well as 303) if you get it replaced.
Old Jun 23, 2011 | 07:02 AM
jsonkimz's Avatar
My only suggestion would be try and find another dealer that will goodwill you a new dash. It's a long shot but I would pull out all the stops before I forked over $1800 because Acura can't build a quality product.
Old Jun 23, 2011 | 07:16 AM
LoveMyTL-S's Avatar
Dash carpet?
Old Jun 23, 2011 | 09:49 PM
I hate cars's Avatar
There's a ton of info on this problem and what Acura is doing to make it right. Try a search for cracked dash.
Old Jun 24, 2011 | 08:37 AM
ACURA 2004 GUY's Avatar
Smile Best option
I went to my Acura dealer because my high pressure hose was busted(which was a recall so it was fixed for free)
The Service guy in Ft Lauderdale saw what has happened to my dash(about 10 cracks) and automatically told me he would contact American Honda to see if they would help out.
American Honda responded within 2 days and agreed to pay 90% of my dash replacement. BRAND NEW dash installed out the door for 165.00! I got lucky.
Sometimes its worth checking into to Acura dealer.
Good Luck
Old Jun 26, 2011 | 10:08 PM
sk8board{Pete}'s Avatar
The least acura can do is lower the price for a new dash board!!! Mines is cracked as well and that ish is too much to buy new. If they will reduce the price, I'll buy one a put it in myself... $1800 do replace something they F'd up on.. smh
Old Jul 21, 2011 | 10:56 AM
rbigm's Avatar
3rd Gear
There are many posts about this and i am very surprised that Acura doesnt have a recall for this. It seems like the crack is always on the right side where the passanger airbag is.
I had this fixed w/out any issues at a local dealer. They wanted to split it with me and i told them if they check online this is a huge issue with many Acura owners not just TL.
He contacted American Honda rep and it was replaced for free. Took two days to get it replaced.
I would just go to a local dealer and dont give up...ask for service manager if you have to.
Old Jul 23, 2011 | 07:16 AM
kretek234's Avatar
Hi, I live in Ft.Lauderedale too, which dealer did you go to.
Thank's.
Old Jul 30, 2011 | 10:10 AM
PrissyJayne's Avatar
Glad I did a search for this before posting. Like the OP, my dashboard just cracked yesterday, less than a month after purchasing the car (not CPO). I don't have an Acura dealer close, but I wonder if I can get similar service from a Honda dealers (only an hr drive as opposed to 2+ hrs drive).
Also, does anyone know if this has an adverse effect on the airbag? Mine is cracked directly over the passenger air bag.
Old Aug 3, 2011 | 09:38 AM
dancamp25's Avatar
What dealership did you go to in Fort Lauderdale
Old Aug 3, 2011 | 12:58 PM
ez12a's Avatar
the overexplainer
Honda has officially said it does not affect the airbag adversely, hence no recall.
hedzup
1G RL (1996-2004)
Jun 29, 2016 08:07 AM
Sep 14, 2015 10:09 PM
Stu2414
4G TL Problems & Fixes
Aug 30, 2015 07:30 PM
wendtdc13
1G RDX Problems & Fixes
Aug 30, 2015 06:39 PM
chef chris
Wash & Wax
Jun 3, 2003 08:57 PM
