Dash dimming wont stay
Old Sep 25, 2010 | 11:43 PM
sonicvalley's Avatar
Whenever I put the dash to the dim/brightness setting I want, it wont remember the setting next time I drive. Is this a setting in the MID or somewhere else? Am I missing something?
I did a search but couldn't find anything...
Old Sep 26, 2010 | 01:02 AM
legendbliss's Avatar
when you set the dim to where you want it, set the driver one setting button on the door again. that will set the dim and the seats to whenever you unlock the car.
Old Sep 26, 2010 | 09:12 AM
jokerman826's Avatar
Jokerman
It shoudl stay even without setting it to the specific drivers setting. I set mine to the lowest light output and i just stays there. You also have to remember that if your headlights are on the setting will be different than when they are off. Turn the headlights on, set it, then turn them off and set it. Then you should be fine.
Old Sep 26, 2010 | 09:32 AM
nfnsquared's Avatar
Not sure what year TL you have, but at least according to the 04 owner's manual, the panel brightness setting is not in any way controlled by the driver's memory system.
Jokerman is correct: It should stay in the setting you left it in for the appropriate light switch setting (e.g. headlights on or headlights off).
Old Sep 26, 2010 | 02:09 PM
it is an 05
Old Sep 26, 2010 | 02:24 PM
i also have an 05, and thats how i got it to stay. give it a try!
tsx_boy
Dec 13, 2019 08:33 PM
Jul 16, 2017 07:33 AM
soupi
14
Nov 15, 2015 11:15 AM
hashbrown
Sep 29, 2015 12:13 PM
