cylinder misfiring
Old Sep 12, 2007 | 01:49 PM
jon34's Avatar
A-spec six speed TL
cylinder misfiring
please someone help. all the cylinders are mis firing the dealer says its because of cylinder five and that i need a new cylinder head or a new block there is only12000 miles on the car. all the coil packs and plugs are good can someone give me sum input. is there a way to see if the o2 sensor is bad.
thanks
Old Sep 12, 2007 | 02:20 PM
csmeance's Avatar
which dealer? Did the car get hydrolocked or have any mods? DId you fill up gas recently? My bet would be on the gas if the car had no mods or was not hydrlocked.
Old Sep 12, 2007 | 02:25 PM
Turbonut's Avatar
A bad O2 sensor won't cause a dead miss. Hopefully the dealer took a compression test and found out that #5 is kaput. If the dealer took a compression test, what were the results? Could be many problems, from valves, camshaft, head itself, block, etc. Have even seen a fuel injection go bad/clogged and cause a non firing cylinder, but not low compression. Many reasons, but you'll need to find out what the dealer did, or didn't do to come his decision.
If under warranty, why worry about a fix if you not familiar with the car? Just let them do the work, or take it to another dealer for a second opinion.
Old Sep 12, 2007 | 04:51 PM
harddrivin1le's Avatar
Originally Posted by jon34
please someone help. all the cylinders are mis firing the dealer says its because of cylinder five and that i need a new cylinder head or a new block there is only12000 miles on the car. all the coil packs and plugs are good can someone give me sum input. is there a way to see if the o2 sensor is bad.thanks
The dealer isn't likely to make something like that up.
Ask them *HOW* they came to that conclusion.
The O2 sensor has nothing to do with this...
Old Sep 12, 2007 | 05:00 PM
Xx06SickspdTlxX's Avatar
06 TL 6spd. Navi/A-spec
Well im sure if the dealer said that you need a new block and or heads that they performed either a compression test or leakdown test to see if any of the cylinders are bad or vehicle has bent valves. Missfires can be caused by several things, its just a matter of some diag to figure it out, if the car has only 12k miles then this should be covered under warranty. As long as they cant prove that the engine was damaged by a misshift or abuse.
Old Sep 12, 2007 | 05:04 PM
If it were me I'd have the parts replaced under warranty and then dump the car.
Old Sep 12, 2007 | 06:45 PM
jon34's Avatar
A-spec six speed TL
i just found out that they did a compression test where cylinder 5 is alot lower than the other cylinders 110 to 120 and the others where 170 to 180. the day it started i kick it i was in 3 and i shifted to 2 where i had to go in 4 and the rpm shot up when i got to where i was going it started to run funny. I told my budy that i mess up on my shifting and he said that it should have nothing to do with that. the dealer saidthat something is bent in cylinder 5.
Old Sep 12, 2007 | 07:16 PM
Turbonut's Avatar
Yup, another missed shift! It'll do it everytime, especially when the engine screams beyond the redline.
Old Sep 12, 2007 | 07:41 PM
You'll need to have that fixed.
Obviously it's not an O2 sensor...
Your buddy has no idea what kind of revs were involved when you accidentally hit 3nd gear, so his opinion doesn't really mean a whole lot.
A quick 10K rpm spike will fry the engine.
And chances are the damage isn't limited to cylinder 5.
Old Sep 12, 2007 | 07:43 PM
01tl4tl's Avatar
I always love it when the vital detail finally comes out-
Was looking for 4th gear when I found 2nd and the redline was exceeded by a LOT
The engine probably went into safe- limp mode to get you off the road and to the dealer
OK so what happened is you over revved the engine and bent a valve when it hit the top of the piston- at the very least- on number 5
Until they take the top of the engine apart to get to it- there is no telling for sure what happened beyond that like camshaft damage and piston damage and other cylinders may be in danger too
I thought all our cars have a rev limiter? Not on the MT cars?
What did they say about warranty-? you could be looking at 4-5 gs depending- or 1500
Old Sep 12, 2007 | 07:50 PM
NOTE:
A redline shift from 3rd to 2nd gear in a 6 speed TL will result in roughly 10,000 RPM...!!!
That's enough to fry the engine - instantly.
Rev limiters don't work with manuals when downshifting. They only work when shiting up by limiting RPMS.
The revs you get when you downshift are dictated solely by the gear ratios and vehicle speed.
He likely saw something very close to 10,000 RPM when that happened, since 3rd's ratio is 1.7:1 while 2nd's is 2.478. That's a factor of 1.46. (6,800 RPM in 3rd will equal 6,800 RPM X 1.46 (9,900 RPM) in 2nd for the same vehicle speed).
Old Sep 12, 2007 | 08:00 PM
01tl4tl's Avatar
bogus bummer dude
I really appreciate the TLs Tiptronic now!
Old Sep 17, 2007 | 08:20 PM
jon34's Avatar
A-spec six speed TL
today i found out that it is not only cylinder 5 there is 3 cylinders with low compression. tommorrow i am going to get a quote to fix it and i hope its going to fix it.
thank guys i'll keep you posted on what happenes.
Old Sep 24, 2007 | 08:56 AM
jon34's Avatar
A-spec six speed TL
i got the car back yesterday. and everything is good it had 6 bent valve got that fix and it runs good.
THANKS
Old Sep 24, 2007 | 10:33 AM
timmahh's Avatar
it's me, Alan Rickman.
how the hell did you end up with 6 bent valves?
You have a 6 speed...... dun dun dun... miss a shift?!
Old Sep 24, 2007 | 11:12 AM
01tl4tl's Avatar
wow- you lucked out
Now go take a track day driving school and learn how to make sure that never happens again
Old Oct 5, 2007 | 10:19 AM
6SPDTLNTX's Avatar
I had the exact same thing happen to me with 27k miles on my TL. Are you saying that you got this fixed under warrenty?
SidhuSaaB
May 30, 2020 12:40 AM
Jul 16, 2017 07:33 AM
joflewbyu2
Oct 8, 2015 11:16 AM
kencepeda
Sep 26, 2015 05:13 PM
