Cruise control master switch
Old Jun 24, 2011 | 04:49 PM
hipposon's Avatar
The cruise control master on/off switch stopped working (won't stay on). Symptoms: When I press the master on/off button, the green dashboard light turns on, but only while I hold the button down. To be clear, I am NOT trying to engage the cruise control, just turn it on.
[only as a test] Oddly enough, if I press and hold down the master switch and simultaneously engage the cruise control to hold a speed, it works. The second I remove my finger from the master on/off button, the master light goes off and cruise disengages.
Make sense? Does anyone have a quick fix? 2007 TL with Nav, 55k miles, just went out of warranty. Acura service wants $130 just to diagnose the problem.
Old Jun 27, 2011 | 02:27 PM
LoveMyTL-S's Avatar
May be a bad cruise control switch.
Old Jun 27, 2011 | 09:19 PM
dwb993's Avatar
Most likely a broken spring within the switch button itself. Replace the entire unit. Theres a DIY in the 3G Garage for replacing your steering wheel lights that should have all you need for the actual process.
Looks like #1 ($146) here:
https://www.oemacuraparts.com/index....%20%28%2707%29
Old Sep 29, 2011 | 08:56 AM
psuprav's Avatar
I have the exact same problem with my '04 TL... the cruise master switch won't engage on it's own, but if I hold it down then set the cruise, it works.
Did you have this repaired? How much did it cost you?
Old Sep 29, 2011 | 06:36 PM
My mothers '01 Olds Alero had the same problem and the link below is what I used to fix it.
http://oldsmobileforum.com/forum/showthread.php?t=2895
Now I understand that the Olds is far from being a TL; however, if you can remove the switch and disassemble it, perhaps the fix is as simple as illustrated for the Olds.
I was going to purchase a whole new cruise switch harness from GM for $40 shipped. Then I would have had to replace it on the steering wheel, which did not look like fun, so I googled and it delivered the gem above to me.
Good Luck!
Old Oct 3, 2011 | 09:11 PM
espi_007's Avatar
Still trying to figure out how that cruise control works haha. New to TL world
4drviper
Apr 23, 2025 07:13 PM
blacktsxwagon
Oct 27, 2015 10:12 PM
detailersdomain
Wash & Wax
Oct 9, 2015 10:13 PM
joflewbyu2
Oct 8, 2015 11:16 AM
eastcoastguy
Sep 23, 2015 06:29 AM
