CRANK No start after replacing starter
Old Sep 1, 2020 | 07:41 PM
Hp98's Avatar
Did t belt and w pump. Cleaned intake mainifold, replaced valve cover gaskets and seals because I did a valve adjustment (BARLEY). The car drove fine for a few days then I noticed temp rising randomly and would go back down. Never went over 3/4. At this point I had replaced the entire cooling system As I forgot to mention. Well after a couple days I was getting the random miss fire code so I unplugged the battery replaced 3 coils and checked plugs that I was told have been replaced ngk. Put it all back together and the assessoried worked but car wouldnt turn over. Replaced battery and starter now the car cranks but does not start.
Old Sep 1, 2020 | 08:39 PM
go back over your work, look at every sensor/plug/connection.
Since you did so much, there isnt really a good starting point....you're just gonna have to dive in and look for something wrong or incorrect. maybe a fuse? maybe replaced coilpacks with non-oem? maybe timing is off? maybe battery is dead? maybe starter is bad?
there is so many variables at play and without the car in front of us, it's hard for us to help diagnose it.
Old Sep 2, 2020 | 01:48 PM
El_Cheapo's Avatar
Well, you're going to have to begin by getting the car running. A couple of things to check:
  1. Visual inspection of all the plugs you touched.
    1. Check everything is plugged in and no wires were cut i.e. crank & cam sensors, injector and coil plugs, etc..
  2. Is the green "security key" stuck flashing or does it turn off.
    1. Stuck flashing - the immobilizer has disabled the fuel pump. The car will crank but not start
    2. Turns off - immobilizer is not the problem. Continue on.
  3. Scan for codes
    1. Can you communicate with the PCM/ECU?
  4. Does it crank normally or weak?
    1. Weak crank - electrical power loss.
  5. Check for spark
    1. No spark - check for blown fuse for ignition power. Check for cam and crank signal.
    2. Weak spark - electrical power loss
  6. Check for fuel
    1. Check for injector pulse with noid light
    2. Check fuel pressure
Old Sep 7, 2020 | 12:25 PM
so, what was the result of you double checking your work>?
Old Sep 8, 2020 | 11:40 AM
El_Cheapo's Avatar
You know the deal.
Hp98 ain't coming back to give us some closure.
r/OpDoesn'tDeliver
Old Sep 8, 2020 | 06:31 PM
Old Sep 14, 2020 | 07:35 AM
DMZ's Avatar
DMZ
Head a da Family
Check the + battery cable. At this age, it could be corroded internally where you can't see and not able to carry enough juice to trigger the starter.
Old Sep 14, 2020 | 12:31 PM
El_Cheapo's Avatar
If you would have bothered to read the thread, you would know that OP is long gone.
Old Sep 14, 2020 | 12:38 PM
OP logged in on 9/8 but then didn't bother to check his thread... i feel so neglected
Old Sep 15, 2020 | 09:21 AM
GhostTL09's Avatar
lol
Old Sep 16, 2020 | 02:03 PM
El_Cheapo's Avatar
Maybe it's time to start banning people that don't follow-up.
Old Sep 16, 2020 | 02:04 PM
Maybe he's busy with the hurricane and isn't prioritizing AZ over his own life..
Regardless, grounds for ban if you ask me
TheSauceBoss
Jul 15, 2020 09:40 AM
Pdxnando
Aug 26, 2019 03:56 PM
01RedCLS
Nov 2, 2012 01:06 PM
jumpmanbsktbll
Oct 2, 2006 08:39 AM
Loseit
Jul 6, 2002 06:47 AM
