Crank no start
Old Jan 3, 2019 | 11:29 PM
Dslate44's Avatar
Crank no start
i have a 2004 acura tl i have had for about a month, if i get in it and turn the key right away it makes a werid buzzing noise in the key switch area, then later on in the month i had a check engine light come on and then it shut off and started dumping fuel out of the throtal body, i towed it home i pulled plugs checked timming belt and changed oil due to It smelling lik gas after the night of miss fire and shutting off, i put it all back togther and and it wouldnt start i noticed fuse for the ignition was blown i replaced it and then it started and it ran for about 3 min and blew fuse again and melted the top of coil 6 i bought new coil changed fuse and it ran fine after that, i drove it to work the next day and when i went to leave work the green light was on the dash and blinking the key and know it wont start i had a lock smith come out he tested the keys and the read ring and all was good but his scanner wouldnt sync to the ecu as if it wasnt there at all, the car will crank but no start, i don’t understand why it ran great and then know the imobolizer is light is on neither key will start it iv tried everything its been sitting at my work for a good 5 weeks know!!
Old Jan 4, 2019 | 09:23 AM
Ron A's Avatar
Administrator
Welcome to the forums.
This thread has been moved to the model specific forum for better response.
limamike
Jan 29, 2019 07:46 AM
Michael3.2
Dec 20, 2018 09:57 PM
Abraham Shield
New Member Introductions
Dec 15, 2018 11:34 PM
Alonso Rodriguez
Dec 8, 2018 03:50 PM
