Couple questions about my newly purchased 06 TL 6spd
Hello everyone!
Just bought a 06 TL with 80k on it, came with the Type-s wheels and Front brembos. The person I bought it from is not the one who made the modifications. I was curious, are the rear brakes on the type-s the same as the ones on the standard TL? If not how would I be able to tell if they are the Type s rear breaks or the stock ones. Obviously you can just look at the fronts and tell.
Also the car did not come with the manual so i need to find it online. In the meantime could someone recommend how often to change the transmission fluid? I usually go with GM fluid, if anyone thinks thats not a good idea please let me know.
Thanks for any help, I look forward to doing lots of research on here and contributing where I can!
Very cool and good to know!
Wasn't much history on the car I purchased, I was going to change the oil and tran fluid this weekend. I noticed when driving around town that the console area right past the shifter like right inside the 2 little bays gets very very hot like almost to hot to touch is this normal since the transmission is right below there or should I be concerned? It does not get that way when cruising on the highway.
The following 2 users liked this post by erg69:
justnspace (04-13-2015),
polobunny (04-13-2015)
^no, some one recently bought a TL, just like yourself...
asked why it was so hot from the cubby near the shifter.
I chimed in saying it was normal, because engine/transmission is right underneath.
the dude took apart the center console and found that a "plug" (i dont remember what it was) was not seated correctly and letting hot air enter the cabin
TL;DR
if you're curious take apart the center console and see if you can find anything abnormal
TL;DR
06TLBleepBlurp (04-13-2015)
Yeah, sorry I can't find it. I think it was in a several question thread, not one titled "hot console" or something easy to find like that.
Either way, it was a lot of work to fix. I remember that much.
cycdaniel
12-17-2019 10:58 AM
