Coolant Problem
Old Jan 4, 2011 | 03:14 PM
Trunk Monkey's Avatar
Coolest A-zine Member
Coolant Problem
About 6 days ago I got home from a roughly 20 mile drive and I started to smell coolant when I parked and began to walk inside my place. I lifted up the hood and realized that the small hose that goes from the radiator to the coolant reservoir had popped off the nozzle that is connected to the reservoir. Naturally, there was coolant EVERYWHERE on the plastic parts, all over the fan, on the block, etc. I cleaned all the plastic parts with a Simple Green solution but didn't get down deep into the block, hoses under the fenders, fan, etc. I'm still smelling coolant to this day. My Temp. Gauge just sits at halfway like normal, no smoke from the tailpipes that I know of so is this just a case of the coolant that got all over everything burning while the engine is hot?? I was going to try to hose everything down b/c I know you can just hose the engine compartment down but you have to be careful of certain parts of the compartment.
I was wondering if anyone has had this problem or recommends hosing it off to get all the coolant off all the engine pieces. If I did hose it down, what stuff would I need to cover up? Thanks for the help
Old Jan 4, 2011 | 03:16 PM
cover up the alternator, battery. fuse box. with grocery bags.
then proceed to spray with hose.
Old Jan 4, 2011 | 03:23 PM
Majofo's Avatar
I wouldn't even cover said items but better safe than sorry.
Old Jan 4, 2011 | 04:15 PM
Ok I'll give it a go after work and see what happens. Thanks guys!
Old Jan 4, 2011 | 04:16 PM
Majofo's Avatar
Old Jan 4, 2011 | 06:06 PM
RIP? Ok...not doing it now. Is my shit gonna blow up!
Old Jan 4, 2011 | 06:14 PM
Majofo's Avatar
We're just messing with you.
Old Jan 4, 2011 | 06:44 PM
lol
Old Jan 5, 2011 | 08:38 AM
did you wash the engine bay, yet?
Old Jan 5, 2011 | 09:28 AM
...no lol
Old Jan 5, 2011 | 01:22 PM
I hate cars's Avatar
As long as you're just running water over it without a lot of pressure you don't need to cover anything up. It's the high pressure stuff that gets past weatherpack connectors and gets trapped in there that causes issues.
Old Jan 5, 2011 | 01:37 PM
Thanks. I'll just run water over it and see if I can't get it to come off in most places, though I might need some pressure on the bare metal spots.
SidhuSaaB
May 30, 2020 12:40 AM
LeVeL
Oct 18, 2015 04:19 PM
12vancover
Oct 16, 2015 12:04 PM
ROSSARONIE
Oct 2, 2015 11:46 AM
Username 0
2G TSX Performance Parts & Modifications
23
Sep 28, 2015 09:09 AM
