Cold weather tire pressure
Old 01-02-2012, 09:17 PM
danl23880's Avatar
I am curious to which tire pressure i should be at. Car seems to slip a bit in the cold. I live in illinois and it is now winter.
Drive a 08 acura tl type s with yokohama avid envigor tires.
Tires are like new and my current pressure is 36 or 37.
Max psi on tire says 40.
What should i be at and am i to high?
Old 01-02-2012, 09:20 PM
3G TL/2G MDX Owner
TLtrigirl's Avatar
what does your door placard say? is the psi you give the COLD tire pressure (ie first thing in AM)? what size tires?
Old 01-02-2012, 09:23 PM
Andy Tsang's Avatar
IIRC, cold tire psi for your car should be 35 in the front and 32 on the rear.
Old 01-02-2012, 09:49 PM
danl23880's Avatar
thanks and it is about 37 psi cold. Tires are stock for my 08 type s. 17 in rims. Do most people always put more air in front and less in rear.
Old 01-02-2012, 09:52 PM
Andy Tsang's Avatar
I would just follow the psi amount posted on the door sticker. I find that when I keep it at that and drive around the psi can go up 3 psi.
Old 01-02-2012, 10:02 PM
danl23880's Avatar
sounds goo thanks but should i have more air in the front and less in the back? Or same all around is good?
Old 01-02-2012, 11:22 PM
the overexplainer
ez12a's Avatar
fronts should have a little more since the weight of the engine changes the tread profile I'm guessing. More air to compensate.
Bearcat94 (01-02-2012)
Old 01-02-2012, 11:23 PM
runnin a little boost
Hi speed's Avatar
You run less pressure in the rear to aid in traction since the rear is lighter than the front.
Old 01-02-2012, 11:35 PM
AZ Community Team
Bearcat94's Avatar
Received 7,770 Likes on 4,341 Posts
Those are the best posts I've read to explain why the OE pressure recommendations are they way they are.
Old 01-02-2012, 11:38 PM
Resident Dingo
TheDingo's Avatar
Since tires require various things as they differ, it is always a good idea to look at the tires on the car rather than check the information on the door of the car.
With a maximum PSI of 40 on those tires, your cold tire PSI should be ~32. Typically, warm tire temps should be ~80% of the maximum PSI.
As mentioned before, some run less pressure in the rear for navigating snow/ice conditions, but that's up to you.
Old 01-02-2012, 11:55 PM
danl23880's Avatar
thanks for all the help I went with 35 and 32. I might bring down the fronts 3 psi or so. This is what car reads right when i start it. COld start and temps are about 20dg around here. Hope it handles better.
Silvermoon_Knight
10-22-2015 06:25 PM
lland
10-04-2015 04:47 PM
forrie
09-15-2015 09:57 AM
Quick Reply: Cold weather tire pressure
