Cold weather tire pressure
I am curious to which tire pressure i should be at. Car seems to slip a bit in the cold. I live in illinois and it is now winter.
Drive a 08 acura tl type s with yokohama avid envigor tires.
Tires are like new and my current pressure is 36 or 37.
Max psi on tire says 40.
What should i be at and am i to high?
Bearcat94 (01-02-2012)
AZ Community Team
Received 7,770 Likes
Those are the best posts I've read to explain why the OE pressure recommendations are they way they are.
Resident Dingo
Since tires require various things as they differ, it is always a good idea to look at the tires on the car rather than check the information on the door of the car.
With a maximum PSI of 40 on those tires, your cold tire PSI should be ~32. Typically, warm tire temps should be ~80% of the maximum PSI.
As mentioned before, some run less pressure in the rear for navigating snow/ice conditions, but that's up to you.
thanks for all the help I went with 35 and 32. I might bring down the fronts 3 psi or so. This is what car reads right when i start it. COld start and temps are about 20dg around here. Hope it handles better.
TLDude876
12-28-2016 03:18 PM
rockyboy
01-25-2016 06:00 PM
Silvermoon_Knight
10-22-2015 06:25 PM
