cold engine noise
Old Apr 18, 2006 | 06:40 PM
honda nut's Avatar
cold engine noise
I have a 06 tl 6sp with approx 1700 miles. The car is less than 2 months old and ever since I got it It has made a slight tapping noise when cold. It did not seem right but I just figured I would wait and see if it go away when the warmer weather arrived. Well its getting warmer and now the noise seems to be getting worse, it now sounds more like a knocking sound! Will leave it at dealer next tues.Here's my question? Has anyone else heard any kind of engine noise when engine is cold?This afternoon I started the car and let it idle down, with my window open I could here a definite rapping sound as the engines rpm's came downand continued to make the noise as I started pulling out of my parking space.If anyones interested when you have time, listen to your engine at first startup and let me know your findings?Thanks
Old Apr 18, 2006 | 10:34 PM
edsonfire's Avatar
05' WDP A-SPEC
i posted a thread about this a couple months back. i got the same deal goin on in my 05/6mt. i just finally got around to getting it serviced. i head on vacation the first week of may and im leaving it with my dealer to see whats up with that ticking amongst other things. mine hasnt gotten any worse though. if it gets worse, u might have a bad problem. in my opinion on my car, i just think the valves need adjusted. adjusting the valves is a regular maintanance that needs performed on acuras. check ur service manual and youll see when the adjustments should be made. granted i think its wierd that its ticking already considering i only got 9000 on mine, but i guess well have to wait and see when i take it to the dealer in 2 weeks. ill let u know when i find out what the deal is. if u find out anything, let me know also.
Old Apr 18, 2006 | 10:41 PM
twigglius's Avatar
we live in a simulation
Is it a knock or a click? My 06 TL is 3 months old and sometimes when I start the car there is a clicking noise during the start.
Old Apr 19, 2006 | 06:56 AM
honda nut's Avatar
The noise I hear seems more like a rapping noise.This morning I let it idle down and it did not make the noise until I raised the rpm's fron 1000 to 1300 then I heard the noise, it went away when the rpm's went above 1400. There is no noise when engine is warm.Sounds to me like lack of oil somewhere.
Old Apr 19, 2006 | 07:59 AM
bdcleav's Avatar
4th Gear
You might check the Service Thread at the top of this page and look at the March 2006 Bulletin.....it talks about possible solution for pinging sound in the engine....
BC
Old Apr 19, 2006 | 07:27 PM
honda nut's Avatar
Went outside at lunch time to see if it would make noise after being off for about 5 hrs, sure enough after starting I was able to reproduce the rapping noise by slowly increasing rpm's from idle to about 1300rpm's and holding it there. With the hood open and my friend in the car I was able to hear the noise coming from the area of the rear valve cover.But the noise sounds more like a piston slap than a valve tap.It also doesn't go right away, it was making the noise for several minutes.It was not making noise at idle or above 1400 rpm's.
Old Apr 19, 2006 | 08:57 PM
05TLTony's Avatar
Dr. Feelgood
I had the same problem with the ticking / knocking sound coming from the rear of the engine. You can hear it from the outside but not from inside the car, correct? I've asked this question awhile back and was told that it was the fuel injectors. People said it is a characteristic of Hondas.
Old Apr 19, 2006 | 10:00 PM
SilverUA5's Avatar
Does it sound like a fan belt that needs some WD40? If it is, I had it before and it went away, then I found out it was the heat shield.
Old Apr 20, 2006 | 12:32 PM
honda nut's Avatar
This noise I hear is an internal engine knock! It starts making the noise while the engine warms up then goes away after a few minutes.You can only hear it between 1000 and1500 rpm's.
Old Apr 24, 2006 | 01:38 PM
I hate cars's Avatar
From the description I would almost lean toward piston slap. My fast car has it when cold and it's normal and doesn't lead to extra wear or breakage. I wouldn't think the TL would need that much clearance though.
I was going to say a single header leak can sound like a valve tick and go away when hot also but these cars don't have individual headers.
Old Dec 24, 2008 | 03:01 PM
Harrisonk531616's Avatar
CL-SEXY SIX (=
i have the same exact problem...did we ever find out what this problem was?
rockyboy
Aug 4, 2024 10:35 AM
01CLOwner
Oct 9, 2015 01:07 PM
iCrap
Sep 11, 2015 06:21 PM
dlknight
Sep 3, 2015 07:54 PM
