Coil Pack Bolts
Old 09-09-2010, 11:13 AM
thrasher865's Avatar
Coil Pack Bolts
So, while changing my spark plugs yesterday, I managed to shear off the bolt holding in one of my coil packs. Does anyone know the part number for these or installation/removal process?
Do they thread in? Like would I be able to back it out with a bolt extractor and then tighten a nut onto the new one all the way down and torque it in with a deep socket, then back the nut off? This sucks. It's one of the back ones, too, so whatever the procedure, I'll have no room at all to work.
Old 09-10-2010, 08:37 AM
I know this isn't the first time this has happened.
Somebody has to have some insider information. I just got the car and have yet to get myself a Helm manual.
Old 09-10-2010, 09:05 AM
danny25's Avatar
Are you talking about the hex key bolts? Was that the first one you tried? They just unscrew, try one of the front ones.
Old 09-11-2010, 11:29 AM
01tl4tl's Avatar
Received 1,137 Likes on 1,067 Posts
allen head bolts- use screw extractor as you had figured already
look at parts store- or good hardware store may have the same, or dealer locally so you get it back in now
Old 09-11-2010, 11:30 AM
01tl4tl's Avatar
with the coil removed can you grab the broken bolt with small vise grips and work it out
or if there is enough threads exposed to double nut it and back out that way
remove a front so you can see what length you are dealing with
Old 09-12-2010, 03:12 PM
I don't know what hex key bolts you're talking about these just have nuts threaded over them and hold the coil pack onto the head. There are several threads exposed but not enough to get two nuts on there.
tsx_boy
12-13-2019 08:33 PM
Kres43
1G RDX (2007-2012)
10-03-2015 07:16 PM
Sarlacc
Console & Computer Gaming
09-30-2015 02:15 PM
NorthWestAnimal
09-28-2015 06:20 PM
ROSSARONIE
09-22-2015 11:46 AM
Quick Reply: Coil Pack Bolts
